New Member
Discussion in 'New Member Introductions' started by toyota samoan, Nov 6, 2016.
  1. Nov 6, 2016 at 11:21 AM
    toyota samoan
    toyota samoan [OP] New Member
    jason
    2012 toyota tundra SR5
    none
    hey guys ,just wanted to introduce my self ,im a new owner of a 2012 Tundra SR5 ,looking for some info on a leveling kit and new rims and tires !
    T-Rex266 and TXMiamiFan like this.
  2. Nov 6, 2016 at 11:24 AM
    Welcome.
    As long as you're not from Colorado....(inside joke)
    What are you looking for in a leveling kit?
    Spacers ride like a lumber wagon, adjustable shocks are decent, coil overs give you the "O Face" every time you put the truck in drive.
  3. Nov 6, 2016 at 11:38 AM
    Junior4888
    Junior4888 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    Welcome from
    WA
  4. Nov 6, 2016 at 11:46 AM
    462Loadtoad
    462Loadtoad New Member
    Surprise, AZ
    2012 Rock Warrior CrewMax 4x4 5.7
    Upgrade plans are: Zone 5" Suspension Lift Method Double Standard Rims 18x9 Goodyear Duratrac 35x12.5/18's N-Fab W2W Nerf Bars Smittybilt M1 Front Bumper Smittybilt M1Rear Bumper
    Welcome from Surprise, AZ. Not sure how much you've browsed the site but in my opinion this one has way more info in it.
  5. Nov 6, 2016 at 11:57 AM
    ColoradoTJ likes this.
  6. Nov 6, 2016 at 1:55 PM
    They're everywhere!!!!!
    T-Rex266[QUOTED] likes this.
  7. Nov 6, 2016 at 2:33 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
    ColoradoTJ and T-Rex266 like this.
  8. Nov 6, 2016 at 2:46 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome bud
  9. Nov 6, 2016 at 2:57 PM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Welcome from WI!
  10. Nov 6, 2016 at 2:57 PM
    khunk
    khunk Tundra Fan
    Marty
    Leland, NC
    2017 CM Limited 4x4
    welcome
  11. Nov 6, 2016 at 3:47 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Welcome! Probably the least expensive leveling you should consider is Bilstein 5100 shocks. If you want a full 3" lift up front, you can add 1 coach builder shim on each side with the 5100's on the top setting. For the rear, consider Coachbuilder +2 shackles for 1" lift in the rear. If you have 4WD, you should add a diff drop kit to bring your CV angles back to near stock. If you lift the rear, at all, you should add carrier bearing drop spacers, also available from Coachbuilder.
    I would stay away from the spacer kits, unless you don't care about ride quality.
  12. Nov 6, 2016 at 4:18 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Welcome from Texas, Jason!
  13. Nov 6, 2016 at 4:31 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  14. Nov 6, 2016 at 4:32 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
  15. Nov 6, 2016 at 4:47 PM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    Welcome from Texas!
