New member new england
Discussion in 'New Member Introductions' started by Cdog535, Nov 2, 2022.
  1. Nov 2, 2022 at 8:13 PM
    Cdog535
    Cdog535 [OP] New Member
    01 tundra sr5 extended
    Hey I just enrolled in tech school and am learning as I go but I just got my first tundra it’s a 01 sr5 extended cab 150k frame mint body needs work to be perfect it’s got no options but overall good condition I just got it registered so I’m gonna be doing a full inspection to see anything I should replace but a rough list is it has good tires, brakes new lbjs OE catback bumper brake lines and shocks. So far I’ve felt I need to do timing belt and water pump because it’s never been done, locate exhaust rattle, figure out why my oil pressure drops when I brake and figure out what the light wine I hear from the engine while under load. Sorry to spam I appreciate any advice or help I can get on these issues or other maintence items I should look at
    IsaiahCanada likes this.
  2. Nov 2, 2022 at 8:17 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Where about in NE? does oil pressure climb after you accelerate. The oil pressure does fluctuate on these trucks depending on demand. Not uncommon to see it “low”
  3. Nov 2, 2022 at 8:18 PM
    Welcome from NY.
  4. Nov 2, 2022 at 8:20 PM
    Cdog535
    I’m in ct yah so at idle it’s at exactly half then under braking it goes to near zero on the gauge and under acceleration it goes back up to half or a little over I talked to a tech at Toyota and he said he thought it might be an electrical issue but I don’t have any codes and the engine runs so smooth I find it hard to believe I’d have low oil pressure when it doesn’t even burn any
  5. Nov 2, 2022 at 8:20 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. Rough or not, we still like photos of your Tundra.
  6. Nov 2, 2022 at 8:45 PM
    Cdog535
    This probably sounds dumb but this is my first time on a forum so I haven’t quite figured out how I add photos from my phone to post of my tundra but once I do I’ll send them all up
  7. Nov 3, 2022 at 5:27 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  8. Nov 3, 2022 at 8:27 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  9. Nov 3, 2022 at 8:30 AM
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    Welcome from Idaho
  10. Nov 3, 2022 at 9:57 AM
  11. Nov 3, 2022 at 11:03 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Welcome my CT brother
  12. Nov 5, 2022 at 6:21 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
