New Member introduction, and suspension question
Discussion in '2nd Gen Tundras (2007-2013)' started by Tuggy96, Jan 7, 2022.
  1. Jan 7, 2022 at 3:39 AM
    Tuggy96
    Tuggy96 [OP] New Member
    2011 Silver Tundra Tx Edition
    stock
    I recently got my hands on a 2011 Tundra and am loving it. Got it with 138k miles, all stock. Recently put on some 2021 tss wheels to get the old BBS that came stock to repaint. My question on suspension is I daily the truck and have to get down an old torn up road from big rigs to get to work. I'm looking into going for a 3" lift and update the wheels and tires down the road. I'm not wanting to break the bank on the lift since the truck is 2wd and it wont see any crazy off roading, but I'd like something that will last. Thanks in advance!
    raspy87 and Prostar 190 like this.
  2. Jan 7, 2022 at 4:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
  3. Jan 7, 2022 at 5:40 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome, 3" lift+ longevity+ inexpensive does not exist.
    shannon likes this.
  4. Jan 7, 2022 at 5:51 AM
    Welcome from Ohio
  5. Jan 7, 2022 at 6:09 AM
    2mchfun
    Welcome from OKC! Check out Fat Bob's Garage Vated front adj coilovers set at 3", a set of 1.5" blocks and new u bolts in the rear. Front bump stop 1" extensions, front sway bar 1" drop spacers from ready lift. Maybe a rear brakeline ext kit from Ironman or OME just to be safe. Pretty cheap lift. If it won't align, you can either add adjustable UCA's or drop the lift by adjusting the coilovers about 1/4" at a time, which would reduce lift about 1/2" each time. 3"is kinda the max before you can't get alignment anymore with stock UCA. Every case is slightly different though. Good luck!
  6. Jan 7, 2022 at 10:56 AM
    Tuggy96
    stock
    I’m willing to spend a good amount just not of course resi king and or foxes, but lower end I’ll be willing to pay for.
    Thank you for the input, got anything for lead springs? I noticed mine are not just flat but also look like a w.
  7. Jan 7, 2022 at 11:19 AM
    2mchfun
    I went with Dobinson's 5+2 HD packs, just be sure you raise bump stop heighth to compensate or else eventually you will get flat springs again. Many lift with shackles and don't increase bump stop heighth and then blame the springs after the longer shackles force the springs into negative arch when loaded. My truck is kinda unique as it has HD leaf packs, yellow Sumo springs, and Roadmaster Active Susp. HD kit. Plus BDS traction bars and Bilstein 5160 w/resi shocks. I can easily double my payload rating and still not squat very much. Just the way I like it and sometimes use it. Call Anthony at Boss 4x4 and he can hook you up with some Dobinson's leaf packs. Great customer service!
  8. Jan 7, 2022 at 11:41 AM
    Welcome from NY.
  9. Jan 7, 2022 at 5:00 PM
    Tuggy96
    stock
    Any feed back on toytec coilovers?
  10. Jan 7, 2022 at 6:34 PM
    2mchfun
    Respectable choice
    alb1k likes this.
  11. Jan 7, 2022 at 6:41 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I think many folks who have Bilsteins aren't complaining and you won't go broke with em.
    2mchfun and alb1k like this.
  12. Jan 7, 2022 at 6:50 PM
    Tuggy96
    stock
    I see that the toytec website has adjustable coilover 5100's think those would be better over the ones with the just the collars?
  13. Jan 7, 2022 at 6:56 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    This thread may help you decide
    alb1k likes this.
  14. Jan 7, 2022 at 7:05 PM
    Tuggy96
    stock
    Thank you
  15. Jan 9, 2022 at 12:27 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    The ToyTec ultimate 3" lift is a good choice, would recommend either the shackle or spring option over blocks, depending on your rear bushing condition would recommend if you went shackle option to opt for shackle with bushings. Probably one of the best ways to get leveled and some lift.
  16. Jan 9, 2022 at 12:31 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Welcome from SoCal. My current truck is 2WD and has better suspension than most. But that's silly talk.
  17. Jan 9, 2022 at 1:14 AM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Welcome!
  18. Jan 9, 2022 at 6:19 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  19. Jan 9, 2022 at 6:23 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    Welcome from So Cal
