New member from San Jose Ca.
Discussion in 'New Member Introductions' started by Mrjmm, Mar 19, 2021.
  1. Mar 19, 2021 at 10:51 PM
    Mrjmm
    Mrjmm [OP] New Member
    San Jose
    2015 Tundra Trd
    Icon 3.0 lift , Front / Rear bumpers by RC, 35’s by Pro Comp, Tonneau cover retrac,
    Hello
    I am new to this forum I read alot of helpful threads from everyone since I joined. It is also helpful but interesting as well. I have a 2015 Sr5 Trd that Im currently building but I am having a issue myself if anyone has had this problem as well it would help a bunch if you can share what you did to resolve it. the issue I'm having is when I put my truck in drive most but not all the time I hear a type of metal pop noise from the rear. sounds like its more centered on the rear driveshaft but not sure either. the truck drives in all gears ok and 4wheel works too but I might be missing the problem?
  2. Mar 19, 2021 at 11:13 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Might be a universal joint going out or needing greased. Off the top of my head I’d look over suspension too. If you have access to a lift it would make it way easier. If not have a buddy help out by listening (safety) under the truck while you put it into drive then neutral. These trucks have several areas that can become issues.
    I’m in SJ as well, if you need help PM me. Good luck. PS welcome aboard ...
    Mrjmm[QUOTED][OP] likes this.
  3. Mar 19, 2021 at 11:16 PM
    Mrjmm
    San Jose
    2015 Tundra Trd
    I'll give a shot.. Thanks for the information
    Inquiringone likes this.
  4. Mar 19, 2021 at 11:22 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
    Mrjmm[OP] likes this.
  5. Mar 20, 2021 at 4:25 AM
    Welcome from Ohio
  6. Mar 20, 2021 at 5:27 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  7. Mar 20, 2021 at 5:34 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome from Nor Kal
  8. Mar 20, 2021 at 5:35 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Looks like your truck is lifted. Have you dropped your driveshaft carrier bearing? This will help decrease the angle of the drive shaft. The taller the lift the more drop you’ll need.
    https://shop-coachbuilder.myshopify...uilder-carrier-bearing-drop-kit-rear-lift-0-2
    A bunch of washers will work as well.
    And welcome from Sunnyvale!
  9. Mar 20, 2021 at 6:09 AM
    Welcome
  10. Mar 20, 2021 at 6:17 AM
    ToyAddict802
    ToyAddict802 #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Welcome from Vermont
  11. Mar 20, 2021 at 7:05 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  12. Mar 20, 2021 at 7:06 AM
    Welcome from NY.
  13. Mar 20, 2021 at 9:09 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  14. Mar 20, 2021 at 10:35 AM
    Mrjmm
    San Jose
    2015 Tundra Trd
    @Cruzer yes it’s 3.0 lift but I forgot to mention the noise I had since I bought it , not new but I didn’t think much of it because it drove well. First Toyota Truck
  15. Mar 22, 2021 at 9:44 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
