New member from Bailey, Colorado -- 2022 Lunar Rock Tundra TRD
Discussion in 'New Member Introductions' started by Hawkeye2015, Aug 29, 2022.
  1. Aug 29, 2022 at 4:07 AM
    Hawkeye2015
    Hawkeye2015 [OP] New Member
    Just purchased my new Tundra a week ago. I have purchased a Tonneau cover for the bed and a bed rug to go over the existing bed liner. I have a question regarding running wiring for a mobile ham radio from the battery to the cab. I have used one of the existing holes in the firewall, grommeted of course, but I noticed that there is no way to run the new wiring harness across the back of the engine compartment and above the engine as it crosses to the driver-side run through the firewall. I want to be certain that the wires do not get affected by the engine heat. Any ideas?
    Thanks.
    YardBird and Roctane84 like this.
  2. Aug 29, 2022 at 4:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Doesn't the back of the engine bay have enough firewall across the top to run a harness?
    Roctane84 likes this.
  3. Aug 29, 2022 at 4:46 AM
    Welcome from Aurora....
  4. Aug 29, 2022 at 5:23 AM
    Welcome from NY.
  5. Aug 29, 2022 at 5:29 AM
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    Howdy from Eagle!
  6. Aug 29, 2022 at 5:48 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  7. Aug 29, 2022 at 5:51 AM
    Hawkeye2015
    Thank you all. Bakershack: As you have indicated, there is enough room at the back to run the wiring harness, but the real problem is attaching the harness with zip ties or other devices to keep the harness above the engine itself. In other installations I have done, there have been either stock wiring harnesses that ran just under the plastic tray below the windshield and windshield wipers to which you could zip tie the additional wiring intended, or there were other attachment points that would accomplish the same result. However, none of those options exist back in the same area of the new Tundra. I really don't want to drill holes in the plastic tray to zip tie the new harness. Thank you for taking the time to address my question.
    Hawkeye2015
    "Correlation does not imply causation." Albert Einstein
    Bakershack likes this.
  8. Aug 29, 2022 at 6:10 AM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota. If you are unable to get an answer in the new member section, you may want to re-post your question in the “ask a Toyota Mechanic “ thread of the forum. Lots of knowledge folks monitor that thread. Good luck.
  9. Aug 29, 2022 at 6:35 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome, what about running the wires from the battery into the cab? Is there a grommet on the passenger side? I have always run my wires direct into the passenger compartment, sometimes it's on the driver side, sometimes passenger.
  10. Aug 29, 2022 at 8:26 AM
  11. Aug 30, 2022 at 1:37 PM
    Oldguy423
    Oldguy423 Bertha is her name
    Monterey Peninsula
    Charcoal Grey 2014 Toyota Tundra SR5 4x4
    some changes too many to list
    Welcome
  12. Sep 1, 2022 at 7:43 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  13. Sep 1, 2022 at 8:03 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    TRD pro or SR5 TRD?
