New member, Ed tundra031950
Discussion in 'New Member Introductions' started by Tundra031950, Aug 20, 2018.
  1. Aug 20, 2018 at 10:43 AM
    Tundra031950
    Tundra031950 [OP] New Member
    Ed
    2003 tundra
    Been searching around trying to figure out which is best replacement rotors for 03 Tundra. Looking for coated Rotors heavier, thicker, than OEM. Tired of warped rotors.
    Prostar 190, Black Wolf and T-Rex266 like this.
  2. Aug 20, 2018 at 10:50 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Welcome from SoCal. Hang in there, I'm sure one of the members will chime in. You can also search it out, as it may have been discussed in the past.
    Bob likes this.
  3. Aug 20, 2018 at 11:04 AM
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    Bob and porkitt like this.
  4. Aug 20, 2018 at 11:06 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO.
  5. Aug 20, 2018 at 11:46 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  6. Aug 20, 2018 at 1:08 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  7. Aug 20, 2018 at 1:34 PM
    Casper421
    In the woods
    06 DC
    Welcome! Check your brake calipers and see if you have the original WG or the updated WL. If you have the WG’s, I would highly recommend upgrading to the WL’s. Those and slotted rotors will help eliminate warped rotors. Powerstop z36 is a very nice option.
    Black Wolf likes this.
  8. Aug 20, 2018 at 2:42 PM
    Welcome!
  9. Aug 20, 2018 at 2:46 PM
    Welcome from CO! Ditto on the Power Stops. Got them on front and rear for a couple years now. No more front rotor warping.
    Casper421 likes this.
  10. Aug 20, 2018 at 2:58 PM
    Welcome from Texas
  11. Aug 20, 2018 at 3:49 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!!
  12. Aug 20, 2018 at 6:30 PM
    Welcome from Ohio!
  13. Aug 20, 2018 at 6:35 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  14. Aug 20, 2018 at 6:51 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  15. Aug 20, 2018 at 9:17 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  16. Aug 21, 2018 at 1:20 PM
    Tundra031950
    Ed
    2003 tundra
  17. Aug 21, 2018 at 1:34 PM
    Squirrel
    Squirrel New Member
    2011 white sr5
    Welcome from MO
  18. Aug 21, 2018 at 1:35 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Welcome from Texas! I have the power stop rotors. I would recommend them.
  19. Aug 21, 2018 at 2:54 PM
    Casper421
    In the woods
    06 DC
    My 06 isn’t my daily but I have the full z36 kit with rotors and calipers. Haven’t had any issues whatsoever and braking is more firm than stock. Just make sure you break them in properly.
  20. Aug 22, 2018 at 4:39 PM
    Tundra031950
    Ed
    2003 tundra
    Thanks for everyone's input on z36 rotors.
  21. Aug 22, 2018 at 4:52 PM
    Tundra031950
    Ed
    2003 tundra
    Casper 421. What is there to breaking in rotors? Anything special other than taking it easy?
  22. Sep 25, 2018 at 3:31 PM
    Jermalex
    Jermalex New Member
    Central Idaho
    2011 Tundra 5.7L DC LTD
    Billstien 6112/5160 shocks, EBC Rotors and Pads, lots of little tweeks
    I just discovered that my new-used Doublecab has Powerstop Z23 pads and most likely Powerstop drilled and slotted rotors. I bought the rig with 66,000 miles and these already installed so I have no idea how many miles are on the current pads/rotors (I’m only up to 68,000 now). I can say that at least the front pads are still pretty new. They still show a bit of the tapered toe and heel that comes on them from the factory.
    Currently, I get a very noticeable shudder and pulse after the brakes get warm; like when using the brakes in corners while coming down a pass. I’m pretty sure this is due to a warped rotor. Yes, I primarily use my gears on long grades.
    Before I knew they were Powerstops I was strongly considering the Z36 kit to fix my pulse and make an upgrade to my brakes. But now, I gotta say I’ve got some pretty serious hesitation on Powerstop. Even though they’re a bit more expensive I’m considering EBC and SP performance kits now.
    I can’t guarantee that my current brakes were broken in correctly, or that the wheels weren’t over torqued at some point before I bought the truck. There’s lots of reasons other than the quality of manufacturing/design that could’ve caused the rotors to prematurely warp. But, for as expensive as brakes are, I really don’t want to be replacing rotors again before I’ve even gone through a set of pads!
    So, any one out there want to talk my back into Powerstops?
    Anyone have anything big to say about SP or EBC?
  23. Aug 31, 2019 at 12:54 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    Welcome from nj, I'm new here to
