New little leak inside...
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Mar 10, 2023.
  1. Mar 10, 2023 at 9:28 AM
    fighthedude
    fighthedude [OP] New Member
    Hey fellas. I went to drop the kid off at school this morning and noticed i had some water on passenger floor mat. I have not been in the car for a few days. It rained good in nor cal last night. When my AC is running I have always got the drips under the car. I believe that can be a problem for water in passenger's floorboards. I reached up and felt a little drip but it has stopped raining so chasing it might be slightly difficult until this sunday when it rains again. I will include a photo of what I found. I drove from mendo county in rain about 5 days ago in the rain so I suspect it is not all from one afternoon and evening of rain but could be wrong. Do you guys have any suggestions on where to start?
  2. Mar 10, 2023 at 9:33 AM
    Mr Badwrench
    Mr Badwrench New Member
    I have exactly the same leak. Haven't torn into it yet, but I'm subbed for the responses.
  3. Mar 10, 2023 at 9:37 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
  4. Mar 10, 2023 at 9:39 AM
    Windshield cowl is the usual culprit. The small plastic pop in “nuts” that the cowl screws into leak. New ones or some silicone / RTV to seal them usually solves it. Secondary possibility would be windshield seal. It’s a distant second though.
    GeezePlease likes this.
  5. Mar 10, 2023 at 9:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  6. Mar 10, 2023 at 10:05 AM
  7. Mar 10, 2023 at 10:14 AM
    fighthedude
    Thanks for info fellas. If i find culprit will advise
  8. Mar 10, 2023 at 12:12 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  9. Mar 10, 2023 at 9:43 PM
    Bourbon
    Bourbon 2006 Tundra DC V8 4WD
    2006 Tundra TRD DC
    I had a leak in the area you have shown in your image and repaired it last weekend by following the instructional video in the sticky. I took apart the cowl and pulled all 8 of these clips out, cleaned off the destroyed gaskets and replaced with marine grade sealant. My leak went away.
    Besides purchasing the sealant, I had to replace qty 6 of the 9046708184 cowl clips for the lower portion of the cowl. Those were very brittle and broke for me. That was $10 from my local dealer. All other fasteners I was able to reuse.
    fighthedude[OP] likes this.
  10. Mar 11, 2023 at 7:40 AM
    Yeah, I definitely recommend buying replacement clips, both of them part numbers are in the leak thread's cowl leak text description. Better to have leftovers than nothing. I didn't snap all mine, but couldn't figure out how to pop the cowl off without breaking a couple.
    daveeasa likes this.
