New lift - CV angles?
Discussion in 'Suspension' started by Brocksw, Apr 23, 2019.
  1. Apr 23, 2019 at 8:30 PM
    Brocksw
    Brocksw [OP] New Member
    Spruce Mica 2012 SR5 Off-road DC
    Elka 2.5 reservoir front(+3") and rear, JBA UCAs, toytec +1.5" shackle, Falken Wildpeak 285/75r18.
    So my elka coilovers and JBA UCAs are giving me about 3.5" inches of lift on each side. From the reading I've done on this forum I feel like I'm going to have CV or CV boot problems and that might be something that's a little beyond my mechanic skills.
    These pictures are my CVs. Do they look like they're angled too much? Is it worth pulling the shocks and lowering a half inch? I'm not sure how much of an angle is too much compared to stock, but it sounds like it doesn't take much.
    @jberry813 says the front diff drop is worthless... I'm not in a position to argue with him.
  2. Apr 24, 2019 at 5:57 AM
    Brocksw
    No one?
  3. Apr 24, 2019 at 6:16 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    3.5 is a lot. The joints look pretty darn angled. Have you driven a lot to settle them?
    What you need to do is put a floor jack under the cross member and measure how much down travel you still have. I’ll bet there isn’t much. That will really kill ride quality. I think it is recommended to have 20% downtravel minimum, but more will only help.
    On my truck, it rode like crap when my c/o’s were at 3 inches. I turned them down to 2 and ride quality is infinitely better. If i were you I would turn them down one inch each and see how you like it.
    TheBeast and dcsleeper408 like this.
  4. Apr 24, 2019 at 6:19 AM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Get an angle finder measure what you have. If your curious what the diff drop does measure before and after. Be sure to post result if you do. :thumbsup:
  5. Apr 24, 2019 at 6:36 AM
    Brocksw
    Have not driven much... Maybe 50 miles. I'm assuming measuring down travel is center hub to fender and then jack up the cross member until the tires are off and measure the same?
  6. Apr 24, 2019 at 7:21 AM
    Brocksw
    I think im gonna find time to pull my shocks and lower the ride height 3/4" (from 3.5 to 2.75".
    TheBeast likes this.
  7. Apr 24, 2019 at 7:25 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    It's to much , Here is what a cv looks like on a 6 inch bracket lift.
  8. Apr 24, 2019 at 8:40 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes that is correct on measuring down travel. 50 is enough to settle it. I would turn it down to have longer joint life and better ride
    Brocksw[QUOTED][OP] likes this.
  9. Apr 24, 2019 at 8:45 AM
    Brocksw
    My ride quality is actually pretty good so far... Vastly improved over stock. I'm gonna shoot for 3/4" lower. That should help out quite a bit with CV angle.
  10. Apr 24, 2019 at 9:15 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I take it your front shocks didnt come with spacers to drop the front differential? Most lift kits do. That angle is pretty harsh.
  11. Apr 24, 2019 at 9:32 AM
    Brocksw
    They did not. But @jberry813 says the front diff drop is not needed or "pointless".
  12. Apr 24, 2019 at 1:24 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Here is mine with 6inch RC DD2012DD-917B-441E-B09B-5C39A98BBA43.jpg320A5C77-3B3B-43DA-851E-D255CDF45EAC.jpg
  13. Apr 24, 2019 at 1:57 PM
    My angles look just like yours
  14. Apr 24, 2019 at 1:59 PM
    Brocksw
    they do. My CVs look like they're in good shape. I'd like to keep it that way.
  15. Apr 24, 2019 at 2:03 PM
    Yikes! :eek2: I'm on a 6" lift mine look nothing like that, just curious, what's wheel n tire setup? So you don't need a diff drop? What about extended knuckles?
  16. Apr 24, 2019 at 2:07 PM
    Brocksw
    You guys are running bracket lifts though aren't you? I'm just running a coilover.
    Stock wheel with a 275/70r18 in this picture. Going to a slightly taller tire as soon as I get my suspension the way I want it(285/75r18 on the stock wheel)
  17. Apr 24, 2019 at 2:08 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Bracket lift folks :frusty:
    Brocksw[OP] likes this.
  18. Apr 24, 2019 at 2:12 PM
    Yeah spacer lift, blocks in rear, bought used, didn't know what I was getting into when I bought and learned from being on here, but for the off-roading I do (just beach drives), it works for me
  19. Feb 25, 2020 at 11:53 AM
    AZTundra
    Paul
    Phoenix, AZ
    Bringing this thread back to life. Here's my cv angle after front end lift. Does this look reasonable or do you foresee issues down the down? Anyone else have pictures of their 3" lift cv angles to compare?
  20. Feb 25, 2020 at 12:22 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Looks better than mine. Lol
    AZTundra likes this.
  21. Feb 25, 2020 at 12:29 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sorry to hear that, although it makes me feel better about mine. :fistbump: How long have yours been like that? Any issues so far?
  22. Feb 25, 2020 at 1:29 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Nope none at all.
  23. Apr 28, 2021 at 11:03 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    2018 Tundra TRD Sport 4x4
    4” RC lift 35” Toyo 18” KMC Air ride bags for towing
    Did my 4” RC lift, just replaced the CV axles at Toyota after 10k miles. The lift shop did everything but I’m thinking/wondering, could my wheel offset be stretching the CV axle? And that’s why I’m still getting that popping? My angle isn’t bad at all (I’ll post pics in a bit). But could the offset be the culprit?
  24. Apr 28, 2021 at 11:14 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    How has your CV been since you did yours? Mine is a 4” and looks like the same angle as your 6”
  25. Apr 28, 2021 at 11:24 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    is this 4 inch RC a drop bracket lift with the new crossmember?
  26. Apr 28, 2021 at 11:25 AM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    I know it has the drop bracket, not sure about the crossmember... I’ll have to look it up
  27. Apr 28, 2021 at 11:31 AM
    Still same, holding up ok, I bought the RC extended struts and removed the spacers, ride is a lot softer, angles are the same
    Kgfit85[QUOTED] likes this.
  28. Apr 28, 2021 at 11:44 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    your angles should be good if the diff was dropped 4 inches with the 4 inches of lift...
    some guys have the 4 inch drop bracket but spacers that lift the truck 6 inches overall
  29. Apr 28, 2021 at 12:10 PM
    Kgfit85
    Kgfit85 MR MRPH
    Kevin
    Jacksonville, TX
    Talked to a rep at RC and they said to install a driveshaft shim. How would that help the CV angle?
  30. Apr 28, 2021 at 12:20 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Rear driveshaft carrier bearing shim or front shim?
