New LCA's for front bypass install?
Discussion in 'Suspension' started by Marvthehamster, Feb 7, 2024.
  1. Feb 7, 2024 at 3:34 PM
    Marvthehamster
    Marvthehamster [OP] New Member
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI sliders
    Hey gang,
    I'm thinking more about upgrading my front suspension with some bypass shocks. I'll either need to weld tabs to the stock LCA's or get some new ones.
    I have been told by several shops (including ToyTec) that my current LCA bushings/adjuster bolts are seized so at a minimum I'd need to do something about that. It would be nice to get better alignment.
    I'm aware of the Total Chaos and Dirt King arms. Any other aftermarket options to consider? Does MCM make some? I'm already running the rest of the MCM/ADS mid travel kit.
  2. Feb 7, 2024 at 4:32 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    I’m about to do this as well. I’ll be running the Icon S2 mounts and I’ll be welding the included tabs to the stock LCA’s. I’ve read the stock lowers are strong enough to run secondaries without issue.
    I also have a second Icon S2 mount kit if you’re interested.
