New Kenwood Headunit - can't figure out FM reception
Discussion in 'Audio & Video' started by PWMDMD, Oct 4, 2020.
  1. Oct 4, 2020 at 2:48 PM
    PWMDMD
    PWMDMD [OP] New Member
    Worcester, MA
    2020 Tundra Platinum
    Just put in a new Kenwood DMX1037S in a 2020 Platinum. Everything works except FM/AM. I get ONE station which is located in my town, in HD radio, but not a single other station comes in at all, and there are plenty. I've pulled the unit 3x to check the antenna is plugged into the back of the HU and the correct adapter is being used. GPS and SiriusXM both work great.
    I was gentle but unless there's something wrong with the adapter harness or I somehow pulled on the antenna wire going to the factory antenna and it came out of the antenna on the other end or broke the wire, I just can't figure out WTF is going on?
    What are my options? Do they make aftermarket FM antennas for 2020 Tundras with hidden antennas?
  2. Oct 4, 2020 at 7:41 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Can't tell but is the blue wire on that adapter hook up?
    Try tapping that blue to acc wire. Im wondering if the antenna is not getting power?
    PWMDMD[OP] likes this.
  3. Oct 5, 2020 at 3:12 AM
    PWMDMD
    Worcester, MA
    Everything I've seen online about the Tundra has said no power to the antenna and we don't use the small blue wire.
  4. Oct 5, 2020 at 4:58 AM
    BrandonL812
    Brandon
    Oh. Well, im stumped. Good luck though.
  5. Oct 5, 2020 at 4:12 PM
    PWMDMD
    Worcester, MA
    Guess I'm the only one who has ever experienced this? I guess my question is are 2020 Tundra antennas powered?
  6. Oct 5, 2020 at 4:56 PM
    BrandonL812
    Brandon
    Have you try hooking it up to power and see if it does anything?
    Running out of idea.
  7. Oct 5, 2020 at 5:14 PM
    PWMDMD
    Worcester, MA
    Alright...I want to clean up my harness too. So I can tap the yellow 12v wire to power the antenna? Also, since I'm using RCAs for front/rear/subs I can just get rid of all of the speaker wires....correct?
  8. Oct 5, 2020 at 5:21 PM
    PWMDMD
    Worcester, MA
    Also, in the picture above in post #1 it looks like there are TWO wires (1 large and 1 small) on the factory harness...my guess is the small one is for power.
  9. Oct 5, 2020 at 5:28 PM
    BrandonL812
    Brandon
    Yes, you can omit the standard speaker wires since you are using rcas. You can tape them up, make sure the ends of those wire are capped, either with tape or shrink tube. No exposed ends.
    Tap the blue wire from photo in post 1 to an acc wire. If you have posi-tap, that would make it easy.
    You can also use the Blue/white wire on the maestro harness for power too if you want .
  10. Oct 5, 2020 at 6:00 PM
    PWMDMD
    Worcester, MA
    It's even easier...the Kenwood harness has a dedicated wire to power an antenna labeled Ant Cont. Thanks for your help!
    BrandonL812[QUOTED] likes this.
  11. Oct 5, 2020 at 6:01 PM
    BrandonL812
    Brandon
    That's perfect. Let us know your result. Im curious.
  12. Oct 6, 2020 at 12:33 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    My 07 s antenne isn t powered.
  13. Oct 6, 2020 at 3:03 AM
    PWMDMD
    Worcester, MA
    No, but they switched styles in 2019. I do not have a traditional vertical style antenna. I believe it’s hidden in the shark fin now.
  14. Oct 6, 2020 at 5:34 AM
    PWMDMD
    Worcester, MA
    Yup...it’s powered. Hooked up blue wire and stations everywhere.
    BrandonL812 likes this.
