New in Montana
Discussion in '1st Gen Tundras (2000-2006)' started by sgtundra1, Dec 12, 2022.
  1. Dec 12, 2022 at 8:45 AM
    sgtundra1
    sgtundra1 [OP] New Member
    headlights dim even after replacing bulb
    Hi all, I am new here and I need help. I have a 2001 tundra little six cylinder, 4WD. I have discovered the headlights are dim. I had someone work on the trailer lights but I do not know if this has anything to do with the headlights. A friend installed a new bulb and it was dim as well. What would be the first thing to check with this truck? A side note the horse trailer brake unit is not working either. Thank you! Sue
    robabeatle likes this.
  2. Dec 12, 2022 at 8:52 AM
    Welcome from NY.
    Look at the bulb socket for corrosion or animals that chewed the wires.
  3. Dec 12, 2022 at 8:55 AM
    a_double
    a_double New Member
    How does you headlight lens cover look? I had a 2000 and they get pretty dull over time. Maybe see about polishing/restoring the outside.
    ...and welcome!
    N84434 likes this.
  4. Dec 12, 2022 at 9:04 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Hello Sue welcome from Missoula! :wave:
    Where are you located? If you're close to me I can probably take a peek.
  5. Dec 12, 2022 at 9:07 AM
    :thumbsup:
  6. Dec 12, 2022 at 9:42 AM
    The headlights in these trucks are honestly pretty lackluster compared to other vehicles I've owned.
    Stupid question: What's the age on your battery? Have you driven to a local auto parts store for a free battery health test?
    Wahayes likes this.
  7. Dec 12, 2022 at 4:29 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Welcome from Bozeman! These headlights are kinda dim to begin with, but from what I've found the OEM housing fog up pretty badly. Might be worth grabbing a headlight restoration kit for cheap and see if that helps.
  8. Dec 12, 2022 at 4:30 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
  9. Dec 12, 2022 at 4:47 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    This. The socket for the bulb burns out due to corrosion and needs replacement. You can see the corrosion and potential burn marks when you pull the bulb from the socket. You can replace the sockets and wire connection terminations individually using OEM which is more $$ or goto Autozone, buy compatible sockets with wires and splice them into the existing wires for replacement. I did the latter.
    NewImprovedRon likes this.
  10. Dec 21, 2022 at 4:22 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Are you a bot? If you're not a bot say potato.
    shifty`, N84434 and NWPirate like this.
  11. Dec 21, 2022 at 6:20 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  12. Dec 21, 2022 at 7:45 AM
    At first I was, like, "I'm gonna highlight this one thing and give my 2¢", but then I said, "Naw, I'm not gonna be my normal cynical self. Too often I'm dancing that fine line between cynic and realist..."
    But now it's been more than a week with zero response, I'll say it - but feel free to surprise me, OP!
    You and about two hundred other people who've posted this year asking for help, gotten advice, then never bothered to come back :D
    Jack McCarthy likes this.
  13. Dec 21, 2022 at 2:38 PM
    Aerindel
    Aerindel New Member
    Montana
    Welcome from an undisclosed location slightly north of Missoula.
    One theory, there is large resistor that is used for your day time running lights, to deliberately dim them....wonder if the wiring is F'ed up and running your normal lights, through the resistor.
    You could test it out by seeing if there is a jump in brightness between your DTRS and normal lights. Normal lights should be roughly twice as bright.
    shifty` likes this.
  14. Dec 26, 2022 at 4:50 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 does not have DRLs but have headlights that turn off when you shut the engine off and open the driver door so I leave them on all the time for safety. Agree headlights pretty lackluster and polishing them became a monthly chore so I just replaced and run a 55/65 halogen bulb. You could go higher wattage w/ 100W bulbs but best to install a relay kit to save your switches and wiring
