New horn?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, May 12, 2020.
  1. May 12, 2020 at 1:44 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
  2. May 20, 2020 at 11:14 AM
    Bones2012
    Bones2012 2012 CM
    Windy City
    2012 Black Crewmax
    Step Tubes BakFlip VP Dee Zee Bed and Tail gate mats Pop A Lock tailgate lock Smitty Built M1 Rear Bumper Weather Tech mats Interior LEDS Remote control Bed Lights Cabelas seat covers
    I put a 3
    $30 train horn on mine and really like it. Pretty easy to install and did not have to cut or open and factory wiring harness,
  3. May 20, 2020 at 11:18 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Which one did you install?
  4. Jul 26, 2020 at 8:34 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Just bought two replacement horns 130db each but they don't use same connection as the oem horns.
    Is there a harness i can get from oem harness to the two horns that have individual connection plugs?
  5. Jul 27, 2020 at 6:14 AM
    purplenova
    Tom
    Ohio
    How did you wire your new horn?
  6. Jul 27, 2020 at 6:50 AM
    gtoninn
    gtoninn New Member
    Andy
    2015 Tundra Platinum
    When I added Hella SuperTones to my 4Runner I just made a split adapter from the OEM connection to the spade connectors the SuperTones needed. Some wire, spade connectors (male or female) and a crimper and your good!
  7. Jul 27, 2020 at 7:11 AM
    purplenova
    Tom
    Ohio
    I dont have the oem horn in front of me to see the connect plug but
    So if I understand you, you used the "male" spade connector and plugged that into the oem plug?
    and the female spade connector for the new horn
  8. Jul 27, 2020 at 10:40 AM
    gtoninn
    gtoninn New Member
    Andy
    I don't have a Tundra yet but I believe there is a similarity in the connections. They are Toyota's anyway. But yeah I would look at what the current connection is from the truck (male or female) then you are going to make a splitter from there.
    But you want one of these instead of the Male you have listed:
    purplenova likes this.
  9. Jul 28, 2020 at 8:36 AM
    purplenova
    Tom
    Ohio
    Cool - In my last post, I already have those connectors, thats why I was specific with those.
    I appreciate your help.
