New here 2008 4.7 Toyota Tundra and 2010 Toyota Venza
Discussion in 'New Member Introductions' started by JTECH, May 31, 2024.
  1. May 31, 2024 at 11:43 AM
    JTECH
    JTECH [OP] New Member
    2008 Toyota Tundra
    Hi y’all just introducing myself and to give feedback on anyone having issues with check engine light, VSC OFF flashing and traction control light on, I recently had this issue with my 2008 4.7 Toyota Tundra with 196k miles on. First I disconnected both battery terminals for about 30 minutes or so, and all the lights turned off including the check engine, drove it for 50 miles and everything was fine. In the morning when I started my truck to go to work, the check engine light came back on. To make long story short, have me P2443 code ( secondary injection valve) turns out the one of my valves was getting stuck because of corrosion (pump was pumping water or condensation to the valve) paid $308 for the valve and problem solved. Hoping this thread helps somebody like you guys have helped me solve issues multiple times
    JTECH
    tdrcomm and Y0TA PR0 like this.
  2. May 31, 2024 at 11:54 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice! Welcome!
  3. May 31, 2024 at 1:29 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  4. May 31, 2024 at 2:15 PM
    Welcome from NY.
  5. May 31, 2024 at 3:09 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Welcome from VA
