New headlights.
Discussion in '1st Gen Tundras (2000-2006)' started by DirtMerchant63, Nov 12, 2019.
  1. Nov 12, 2019 at 5:56 AM
    DirtMerchant63
    DirtMerchant63 [OP] New Member
    Peter
    '06 Tundra
    Looking for opinions on new lights for the Tundra. Not to customize, but because the old ones are yellowed and fogged. Should I go after market? (If so any suggestions on quality aftermarket?) Or should I go OEM? OEM are pretty expensive but I would like some opinions. Thanks!
  2. Nov 12, 2019 at 6:09 AM
    chphilo
    chphilo Tundra addict
    Western PA
    If yellowing and fogging is your only complaint, I would think that you could just try to restore them first.
  3. Nov 12, 2019 at 6:19 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    https://www.ebay.com/ulk/itm/192842690712
    Crew cab?
    This is a great cost effective option. I was in the same boat as you. My lights were pretty worn inside and out. So I decided to get new aftermarket replacements.
  4. Nov 12, 2019 at 6:19 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While it's been about even responses here regarding 3M or equivalent restoring products, I am in the camp that the 3M product if followed according to instructions, will last until they don't. Perhaps it might have to do with ones location but here in my climate, my restore has lasted 1 1/2 yrs on my 14 yr old 2004. I do need to consider applying some more clear coat.
    I have also seen it posted that Akkon(Taiwan?) has good quality replacements.
  5. Nov 12, 2019 at 6:36 AM
    Professional Hand Model
    Hand Protectors
    Another theory I have is the actual headlamp bulb is doing some damage to the assy as well as the sun.
    Just look at the side markers assy adjacent to the headlamp assy. Mine (OEM side assys) were still new looking, but the headlamps were cooked. Why? See my theory.
    Anyhoo, to Dirt... try Akkons (aftermarket made in Tiawan). They feel more solidly made than the Mainland China ones I had prior for about 5 years. I ordered a set and one of the side markers developed a leak. Went through warranty and they sent an entire new set which are holding well. Some reviewers say their aftermarkets are hard/not able to adjust. These are fine.
    Go ahead and do some Katana LED bulbs while you are at it. Even new incandescents will be an improvement over your current situation. Check my build page for more detail.
    https://www.tundras.com/threads/the...vestment-‘build’-a-chronological-story.46816/
  6. Nov 12, 2019 at 6:42 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Thanks guys... I'll be doing some investigating. I did think about restoring but just never did it my self.. I will definitely look at the Akkons.
  7. Nov 12, 2019 at 6:53 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @DirtMerchant63, if your not doing anything with them, then definitely buy the 3m restore kit. This kit will clean them up nice, but will not remove scratches of any kind. Also another route, which I went was A backing plate with adapter to fit your cordless drill. Buy some orange lake country pads and polish. I purchased all from Autogeek. Just a suggestion. Good luck:thumbsup:
  8. Nov 12, 2019 at 7:18 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Thanks, I'll give it a try. Too baad the weather is starting to change here. Only going to be 29F tomorrow.:rant:
  9. Nov 12, 2019 at 7:19 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Professional Hand Model, really like your link... Thanks for posting..
  10. Nov 12, 2019 at 8:17 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I bought mine off eBay because they were cheaper than Amazon. No real complaints so far and work great. I think I spent $60 for the set.
  11. Nov 12, 2019 at 8:21 PM
    groverdill
    groverdill New Member
    joe
    Rathdrum ID
    I used my HF buffer with a lake county backing plate and pads and wheel polish.
    I just did my new to me LX 470, this took me maybe 10 mins per side.
    Super easy and nearly free, I had the stuff already.
  12. Nov 13, 2019 at 9:17 AM
    DirtMerchant63
    Peter
    '06 Tundra
    WOW! That looks great.. Thanks I appreciate the pics. I will definitely give this a whirl. What grit was your polish? I have 2000 from NAPA for body work.. If that's fine enough I'll give that a shot. You have a dedicated buffer? Is the speed slower or faster than a conventional grinder?
  13. Nov 13, 2019 at 9:32 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  14. Nov 13, 2019 at 9:36 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Thanks revtune. I'll give it a look...
  15. Nov 13, 2019 at 9:41 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    +1 to the Megs headlight coating. I use it on all the headlights I touch up.
  16. Nov 13, 2019 at 10:16 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    I have tried almost every solution offered here and more, including professionally applied ceramic coating, and each one of them does a good job of restoring the headlight lens. However, my experience is that none of them last for more than 12-18 months where I live (CA). After 8-years of fighting it, I finally bought new Toyota OEM headlights this year. Expensive, but willing to pay for fitment and quality to last for years.
  17. Nov 13, 2019 at 10:24 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I think one thing people fail to realize is that the lights require a uv protectant just like your paint.
    How often do you polish and wax your paint? Maybe once or twice a year? Try waxing the headlights at the same time. This will help add a layer of UV protection that will extend the "clarity" period. Even brand new headlights will benefit from that added layer of protection.
  18. Nov 13, 2019 at 12:35 PM
    Hand Protectors
    Good call on this wax on wax off Miagi technique of which the 2002 received plenty in the early years. I still think the damage is from constant daytime running light incandescent heat with whatever groovy cosmic rays those 55w bulbs radiate into the ethereal.
    My theory will be tested now with LED’s inside my new assys. Will have a conclusion in about 8-9 years on said theory.
    TX-TRD1stGEN likes this.
  19. Nov 13, 2019 at 1:00 PM
    DirtMerchant63
    Peter
    '06 Tundra
    Hmmmmm..not sure I can wait the 8-9 year test period...:rolleyes:
  20. Nov 13, 2019 at 1:07 PM
    bvia
    bvia New Member
    2013 Texas Edition Tundra 2WD 4.6 DblCab
    None
  21. Nov 13, 2019 at 1:16 PM
    DirtMerchant63
    Peter
    '06 Tundra
    Didn't know Weathertech made these.. This is a great idea. Thanks. Are weather tech floor mats worth the investment?
  22. Nov 13, 2019 at 1:21 PM
    bvia
    bvia New Member
    None
    They are super thick also. Refinished my wife's 2005 Mazda3S' headlight with the Sylvania kit, then the lampgards 3 years ago and they are still perfectly clear. I know lots of folks are getting tired of me mentioning the kit and the lampgards, but they honestly work as advertised and last.
    I've got weathertechs in my dblcb, but other's swear by different company's products. May as well ask who makes the best seat covers...:rofl::quickdraw:
  23. Nov 13, 2019 at 1:29 PM
    Hand Protectors
    Or, which color sway bar should one get?
    Good concept on the lens protectors, but the cost outweighs the benefit in my opinion. $50 for some thick film is a negative when new assys cost about $115.
    Now, if the assys were very expensive and prone to regular breakage the film makes sense.
    Jackfrost likes this.
  24. Nov 13, 2019 at 1:36 PM
    DirtMerchant63
    Peter
    '06 Tundra
    bvia, yeah I kind of figured everyones got a favorite.. Just thought I'd ask...:thumbsup:
  25. Nov 13, 2019 at 1:43 PM
    DirtMerchant63
    Peter
    '06 Tundra
    I'd agree with you if they have to be replaced every 6 months to a year. But if they hold up for longer might be a good investment especially for newer trucks, vehicles.
  26. Nov 14, 2019 at 6:23 AM
    bvia
    bvia New Member
    None
    Agreed!
    https://headlightrevolution.com/toyota-tundra-07-13-xb-led-headlights/
    The film is really there to stop the surface UV clear coat degradation from environmental hazards (rocks/sand/tar/chemicals) which haze the surface.
  27. Nov 14, 2019 at 8:24 AM
    DirtMerchant63
    Peter
    '06 Tundra
    Yikes! bvia, I think those lights are a bit out of my league.. Nice looking but just need to drive to work and back...Not light a runway..:spending::thumbsup:
  28. Nov 14, 2019 at 9:24 AM
    bvia
    bvia New Member
    None
    LOL...was just reminding PHM that our lights ARE costly...when you upgrade to Morimoto's that is..:spending:
  29. Nov 14, 2019 at 9:36 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Not costly at all for this crowd since it's not an option for 1st Gens.... :thumbsup:
  30. Nov 14, 2019 at 11:33 AM
    Hand Protectors
    Whoa!
    Glad the 1st Gens assys are low cost ($115). BTW, I purchased some Headlight Revolution PerfectFit Fogs bulbs and really like them.
    DirtMerchant63[OP] likes this.
