New head unit - pros and cons of Maestro?
Discussion in '2.5 Gen Tundras (2014-2021)' started by daylorb, Mar 11, 2023.
  1. Mar 11, 2023 at 11:02 AM
    daylorb
    daylorb [OP] New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I'm finally breaking down and putting in a Kenwood head unit with wireless carplay. Looks like there are two ways to go - the Maestro or a standard harness.
    I'm curious what is lost by going to standard harness - there must be something in the OEM display that will no longer work with a Kenwood unit unless the maestro is hooked up? Or is it only cons - i.e. get the OBD data unlocked?
    I don't really need all the OBD features - have a reader, and have the software, etc. but I'd hate to lose something as well.
    Any thoughts would be great, thank you!
  2. Mar 11, 2023 at 11:07 AM
    I think the Maestro let's you retain your steering wheel controls and the display on the dash.
    ** I could be wrong though.
    1lowlife likes this.
  3. Mar 11, 2023 at 11:15 AM
    Meastro retains everything except for the factory mic. You will lose steering wheel controls without it.
  4. Mar 11, 2023 at 11:20 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I don't know what a 'standard' harness is.
    I have the Maestro with my Kenwood HU.
    I've also used it for 2 Pioneer and another Kenwood HU, I easily reflashed it for each one.
    With the Maestro you can flash the steering wheel buttons to do specific tasks, or just use the default and it will work like the OEM HU.
    The only thing it doesn't do that the OEM did, was able to scroll the presets of XM.
    I rarely use the OBO features except for the TPMS readout.
    But I'd say the Maestro is worth the money..:thumbsup:
    https://youtu.be/822YDVj5GoA
  5. Mar 11, 2023 at 1:06 PM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Ah, got it. Sounds like Maestro is the way to go. Def want the steering wheel buttons to work!
  6. Mar 11, 2023 at 1:38 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You can retain steering wheel controls with other modules, but you're maybe saving $50 and not getting any of the other benefits of the Maestro RR mentioned above. I had a Crux SWC module that worked ok, but it was nice swapping over to the Maestro to get OEM controls back in the head unit, along with music info in the center dash.
    daylorb[OP] and 1lowlife like this.
  7. Mar 12, 2023 at 7:26 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    I pulled the factory unit out 2 weeks after I got the truck so don’t really remember much if any type of loss, the maestro with the kenwood was a tremendous gain, as far as sound, info and navigation, and keeping the steering controls a huge plus on my unit as the volume control, and Chanel select are pretty small on the stereo itself
  8. Mar 19, 2023 at 6:29 PM
    Dottat
    Dottat New Member
    You also gain the ability to see exactly WHICH tire is low and also the pressures/temps of the 4 tires.
