New Guy…interested in opinions with 1.5 spacers on factory TRD wheels
Discussion in 'New Member Introductions' started by CementTundy, Aug 28, 2022.
  1. Aug 28, 2022 at 6:19 PM
    CementTundy
    CementTundy [OP] New Member
    2017 Cement TRD PRO
    Leveling Kit , Camper Shell
    Hey guys…I’d like to see a few of your tundras with spacers on your Factory TRD wheels. I’m running 295/70/18 and am thinking about adding an 1.5” spacer to get them out a bit more. Thanks In Advance! FD81F4EA-8450-4B41-9E40-EEF0676F2C0A.jpg
    Hoodrat_tundra and Badknees like this.
  2. Aug 28, 2022 at 6:26 PM
    I think a 1.5 will bring it out too much. It looks like you are right outside of the fenders now. I wouldn't bring it out 1.5 without flares....protect the paint.
    Booney likes this.
  3. Aug 28, 2022 at 6:26 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    35x12.5 Toyo AT III's on OEM BBS Pro wheels w/1.25" Bora spacers.
  4. Aug 28, 2022 at 6:35 PM
    CementTundy
    2017 Cement TRD PRO
    Thanks for the reply Tundra 234...I'm definitely almost flush with the fenders and I think that is what is keeping me from adding the spacers at this point. I was just curious how bad it would chip the paint or affect the handling if any.
  5. Aug 28, 2022 at 6:41 PM
    teamtlr
    teamtlr New Member
    Denver Colorado
    2020 Sequoia TRD Pro
    Sweet looking truck btw. I put the 1.5” on my 2020 TRD sequoia BBS wheels and felt they stuck out to much so i removed them. I also felt like I had a more noticeable wheel bounce going over bumps. I would go with the 1.25” instead. I will give you a good deal on the 1.5” if you go that route. The stud for the lug nuts were almost to short as well so keep that in mind. You only get 3/4 of the bolt threads. Use red loctite as well and check them after 100 miles.
  6. Aug 28, 2022 at 7:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Nice looking truck!
  7. Aug 28, 2022 at 8:07 PM
    Welcome from NY.
  8. Aug 29, 2022 at 8:25 AM
  9. Aug 29, 2022 at 9:24 AM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome and greetings from Minnesota.
  10. Sep 1, 2022 at 10:12 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I've run 1.25" and currently running 1 inch BORA spacers. More than 1" spacers and be prepared for crap to be thrown on the side of your truck. I also run TRD Pro BBS wheels with 295/70 R18 tires. Personally, I wouldn't run 1.5" spacers as the 1" put the tires flush with the fenders. The studs protrude through the rear spacers about 1/8", but the wheel "pockets" will easily accommodate this amount:Bora Wheel Spacer 1.jpg Tundra4.jpg Tundra 120621.jpg
  11. Sep 1, 2022 at 12:01 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  12. Sep 20, 2022 at 3:38 PM
    CementTundy
    2017 Cement TRD PRO
    Thanks for all the replies...BadKnees, Love your Tundra! That's the setup I'm after. I agree with the 1" Bora spacers, it looks awesome. Also, are those TRD Pro LED Headlights hard to wire up since our year models do not have the Daytime Running lights?
    Badknees likes this.
  13. Sep 21, 2022 at 9:37 AM
    Badknees
    Badknees New Member
    South Carolina
    Happy I can help and Thanks for the compliments. I spent a lot of time looking at other member's Tundras until I finally arrived at what I wanted to do with my 2016 1794. The headlights are TRD Pro LEDs and easy plug and play connection with perfect cabling from @iHacker.
