New from south Florida
Discussion in 'New Member Introductions' started by Airbagged, Oct 13, 2015.
  1. Oct 13, 2015 at 9:04 AM
    Airbagged
    Airbagged [OP] New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    New member from homestead, fl.
    Here is a pic of my 2015 Toyota Tundra 2*4 I purchased to tow my camper.
  2. Oct 13, 2015 at 9:05 AM
    Welcome!
  3. Oct 13, 2015 at 9:07 AM
    Airbagged
    Thanks, figured I'd see what others are up to with their tundras
  4. Oct 13, 2015 at 9:08 AM
    Airbagged
    My front end setup, wasn't really looking to lift the truck a bunch, just wanted to level it out, and make weak components stronger
  5. Oct 13, 2015 at 9:10 AM
    Airbagged
    Recently did the Coachbuilders rear +1 shackles, what a difference over stock!
    I also did the urethane bushing conversion
  6. Oct 13, 2015 at 9:11 AM
    Airbagged
    30" rigid industries light to light up the trails at night
    MotoTundra and Joshua1271 like this.
  7. Oct 13, 2015 at 9:12 AM
    Airbagged
    The reason for my truck, I love camping
  8. Oct 13, 2015 at 9:23 AM
    Airbagged
    I did the consol safe the other day like the one in the pic, except I used the Abloy keyed lock.
    rons23 and MotoTundra like this.
  9. Oct 13, 2015 at 9:24 AM
    Airbagged
    I really like the new Coachbuilders heim tie rod ends vs the weak factory ones, which risk pooping off
  10. Oct 13, 2015 at 9:25 AM
    Airbagged
    TRD shift knob
    JROCK915 likes this.
  11. Oct 13, 2015 at 9:26 AM
    Airbagged
    I purchased one of the TRD pro skid plates because it is far better than the cheap stamped steel version that came on my truck
  12. Oct 13, 2015 at 9:27 AM
    Airbagged
    Rear sway bar and Fox 2.0 reservoir rear shocks.
  13. Oct 13, 2015 at 9:28 AM
    Airbagged
    I chose to go with cross drilled and slotted rotors to keep the brakes cool when towing
  14. Oct 13, 2015 at 9:29 AM
    Airbagged
    I had custom pedals made to get a better grip on things
    Ttprodr likes this.
  15. Oct 13, 2015 at 9:30 AM
    Airbagged
    Flush folding bed cover
  16. Oct 13, 2015 at 9:32 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Welcome to the site! Really nice truck! Is that an access panel for the oil filter I see on the PRO skid plate? I find it very annoying I have to remove my plate to change the filter.
  17. Oct 13, 2015 at 9:42 AM
    Airbagged
    Yes it is, worth buying the skid plate just for that access panel
    mdavis[QUOTED] likes this.
  18. Oct 13, 2015 at 9:45 AM
    Airbagged
    Flush mounted rigid industries rear reverse lights
    JROCK915 and T-Rex266 like this.
  19. Oct 13, 2015 at 9:46 AM
    Airbagged
    TRD cold air intake to try and get a little better MPG
    T-Rex266 likes this.
  20. Oct 13, 2015 at 9:48 AM
    Airbagged
    Magnum running boards, I was impressed at how heavy duty these things are.
    rons23 likes this.
  21. Oct 13, 2015 at 9:50 AM
    Airbagged
    First day I brought my Tundra homed parked in front of my custom Scion IQ
  22. Oct 13, 2015 at 10:01 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Welcome! Awesome build.
  23. Oct 13, 2015 at 10:08 AM
    Airbagged
    Thank you, I wanted to build something I could feel safe in towing long distances and going into some back woods campgrounds.
  24. Oct 13, 2015 at 10:38 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Welcome to the forum. I see that you've done your research. Those are some excellent mods.
  25. Oct 13, 2015 at 11:37 AM
    Airbagged
    Thank you, I try not to cut corners
  26. Oct 13, 2015 at 6:22 PM
    JGDarcy
    JGDarcy New Member
    2015 Tundra Crewmax SR5 4x4
    Welcome! I was born and raised in Homestead.
  27. Oct 13, 2015 at 6:25 PM
    Airbagged
    Sounds good, I went to high school here, left for a decade, then came back about 6 years ago.
  28. Oct 13, 2015 at 6:45 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Well I just drooled all over my shirt. Awesome build man!
    Airbagged[OP] likes this.
  29. Oct 13, 2015 at 6:54 PM
    Airbagged
    Thank you
  30. Oct 20, 2015 at 11:58 AM
    Ttprodr
    Ttprodr New Member
    15 CM 4X4 Tundra
    18x9 level 8 Guardian wheels 275/65/18 Coopers ATP Weathertech Mats (black)
    Those are nice,where you get those?
    Airbagged[QUOTED][OP] likes this.
