New from Phoenix AZ.
Discussion in 'New Member Introductions' started by AZ Red Nek, Mar 10, 2021.
  1. Mar 10, 2021 at 9:48 PM
    AZ Red Nek
    AZ Red Nek [OP] Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Hi, I've had the truck for two years, been looking at the posts for info and decided to join.20210310_183605.jpg 20210310_180932.jpg
  2. Mar 10, 2021 at 9:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Welcome from Chandler
    AZ Red Nek[OP] and Bob_Wiley like this.
  3. Mar 10, 2021 at 9:53 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada, nice looking ride
    AZ Red Nek[OP] likes this.
  4. Mar 10, 2021 at 9:56 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA
  5. Mar 10, 2021 at 9:57 PM
    AZBoatHauler
    So.Arizona
    Welcome from southern AZ. Based on the amount of mods on your truck, you’ll fit in well.
  6. Mar 10, 2021 at 10:00 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    I like the grill work! Thinking of adding flashers in that location myself. Is that what you're using those lights for?
  7. Mar 10, 2021 at 10:04 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Welcome from Chandler x2
  8. Mar 10, 2021 at 10:08 PM
    AZ Red Nek
    Chuck
    Thanks, they're combo spot flood, put them in to help see around corners.
    But with the Switch Pro set up they will strobe
    Occidentalis likes this.
  9. Mar 10, 2021 at 10:20 PM
  10. Mar 10, 2021 at 10:48 PM
    AZ Red Nek
    Chuck
  11. Mar 10, 2021 at 10:50 PM
    AZ Red Nek
    Chuck
    Can't seem to attach video, so, if you blink really fast you'll get the idea. Learned what a GIF is today, which proves you can teach a old dog new tricks
  12. Mar 10, 2021 at 11:21 PM
    Bob_Wiley
    Eric
    AZ
    :rofl::rofl:
  13. Mar 11, 2021 at 1:32 AM
    Welcome from NY.
  14. Mar 11, 2021 at 5:00 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Welcome from Tucson! What bar is that? Did you have to cut anything to install it?
  15. Mar 11, 2021 at 5:04 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  16. Mar 11, 2021 at 5:16 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  17. Mar 11, 2021 at 5:31 AM
    Welcome from Ohio
  18. Mar 11, 2021 at 5:53 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Welcome from Chandler!
  19. Mar 11, 2021 at 6:28 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Great Truck!
    Welcome from Winston Salem, NC!
  20. Mar 11, 2021 at 7:55 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  21. Mar 11, 2021 at 11:29 AM
    AZ Red Nek
    Chuck
  22. Mar 11, 2021 at 11:39 AM
    AZ Red Nek
    Chuck
    Thanks, it's a Baja Design S8. You do have to cut 2 holes in the under side of the hood. It has a backlit feature that runs separate from the main light. I went with BD due to brightest light that fits the hood. SDHQ in Gilbert AZ sells a mounting bracket that works perfectly. The bracket is stainless steel so no rust concerns.
  23. Mar 11, 2021 at 1:35 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    It looked like the S8, I have a 20" in the lower grille, just didn't realize a 40" could fit in there!
  24. Mar 11, 2021 at 4:29 PM
    ToyAddict802
    ToyAddict802 #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Welcome from Vermont
  25. Mar 11, 2021 at 4:32 PM
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Welcome from Chandler X 3 - Are those S2's built into the grill?
  26. Mar 11, 2021 at 5:16 PM
    Mhorst1
    Mhorst1 New Member
    Welcome from WA
  27. Mar 11, 2021 at 10:24 PM
    AZ Red Nek
    Chuck
    I miss informed you had to cut 3 holes.
  28. Mar 11, 2021 at 10:25 PM
    AZ Red Nek
    Chuck
  29. Mar 11, 2021 at 10:34 PM
    AZ Red Nek
    Chuck
    Yes they are. I drilled out the corners, roto zipped the sides, used a scientific measurement device aka tape measure. Welded a piece of square tube to 2 pieces of angle iron, put some rivets into the back side of the grill stepped back and was happy that I didn't just ruin the grill.
  30. Mar 11, 2021 at 11:38 PM
    AZ Red Nek
    Chuck
    I also added a pair of lights in the rear bumper, don't like things that go bump in the night.
    TucsonTundra1794 likes this.
