New Ford F150 Tail Light Feature
Discussion in 'Off-Topic Discussion' started by nodak67, Oct 13, 2021.
  1. Oct 13, 2021 at 11:52 AM
    nodak67
    nodak67 [OP] New Member
    JR
    Here’s what those lights are indicating: weight. Yes, weight. Ford has a system they introduced earlier this year called Onboard Scales. It weighs how much is being loaded into the truck and then displays that as a little four-part graph in the taillights, based on the truck’s payload capacity, so you can see easily how much more you can load, right there by the back of the truck. No outside scales necessary.
    https://jalopnik.com/ford-f-150-taillights-have-a-feature-previously-unknown-1847854319
  2. Oct 13, 2021 at 12:27 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    another thing to help them deny your warranty claim because you went over payload 1 time by 5 lbs. Thanks tech!
  3. Oct 13, 2021 at 12:41 PM
    Taco-Spike
    Two Trucks
    I watched a youtube video a few months ago saying it would weigh payload but they never said how it would read it. I figured something in the head unit or center cluster. Nice little feature though. Just adding $$ to the overall.
    I don't think I'd ever care for it, but I don't use my trucks other than personal use.
  4. Oct 13, 2021 at 12:47 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is an idiot light for loading the bed.
    Saltyhero13 and Tundra'25 like this.
  5. Oct 13, 2021 at 1:05 PM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    I always used the rubber axle bumpers for the same thing :D
    bjp, Half Assed and Saltyhero13 like this.
  6. Oct 13, 2021 at 1:42 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    If it indicates the truck is overloaded a little bit will it have to be unloaded to correct payload before the truck can be operated?
    Half Assed, Black Wolf and Shamrock92 like this.
  7. Oct 13, 2021 at 1:45 PM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Although it's cool:
    - More tech to be unreliable
    - What happens with aftermarket tail lights?
    - If I'm over capacity, I probably know already
    - if makes the truck look fragile . . . kinda like "ok, ok, that's enough weight now--ok, you can stop now" (just weird personal opinion)
    Cpl_Punishment likes this.
  8. Oct 13, 2021 at 1:48 PM
    Shamrock92
    Shamrock92 New Member
    Also can be used to indicate when you plan on completing a turn - if only some drivers realized THAT feature.
    Gimmicky and not really useful to me - give me something I can use like a roll down tea window…not a built in scale. Again - it’s a HALF TON truck - how hard is it to calculate 1k pounds of payload ? Most people overload them to begin with the few times they carry cargo.
    Saltyhero13, Tundra'25 and Dr Doobie like this.
  9. Oct 13, 2021 at 1:59 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
  10. Oct 15, 2021 at 6:10 PM
    Kung
    KG, VA
    My question is this - does it record (anywhere at all) what it registers?
    If so, forget it.
    Half Assed and Black Wolf like this.
  11. Oct 15, 2021 at 6:37 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I would not worry about warranty denial with it. It took Ford two years to figure out that people were blowing up the 6.0 liters with programmers.
  12. Oct 15, 2021 at 6:42 PM
    Absolutely.
  13. Oct 15, 2021 at 6:53 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Yo momma so fat when she sits on the tailgate all the lights flash.
    sbxx312, WFD473, Bakershack and 4 others like this.
  14. Oct 15, 2021 at 6:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I hope that someone over at one of those Ford Forums is smart enough to locate the receiver/transmitter, and wrap it with some tin foil. That's what we would do. :tinfoilhat: :)
  15. Oct 15, 2021 at 7:07 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    C.I. likes this.
  16. Oct 15, 2021 at 7:16 PM
    crewmaxlmt
    scott
    Yo mamma so fat, I let her ride in the bed for the Carolina squat!
    Blang805 and Cpl_Punishment like this.
  17. Oct 16, 2021 at 8:44 AM
    Kung
    KG, VA
    My all time favorite:
    Yo momma so fat she jumped in the air and got stuck.
  18. Oct 27, 2021 at 2:37 PM
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    That’s a good way to prevent overload damage. Until someone undoes the fuse
