New ESP Long Box for the CrewMax
Discussion in 'ESP Truck Accessories' started by Viper3G, Jun 15, 2017.
  1. Jun 15, 2017 at 7:10 PM
    Viper3G
    Viper3G [OP] Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    SouthBoundSteve and ep3Jee like this.
  2. Jun 15, 2017 at 8:40 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Yeah I got the aluminum three bin over a year ago and I really like it..Now they come out with the long box..I'd prolly pick this one if it was available back then
    Viper3G[OP] likes this.
  3. Jun 15, 2017 at 10:06 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    I have been working on this for almost a year now. I was not going to say anything until I was sure it was going to work. We had to redo the rails 3 times and the box had to be changed 2 times. Taking my truck apart that many times was super frustrating. I am pretty happy with the way it came out. If ANYONE has questions, give me a call. 951-858-3418. For those of you who don't know, we are in Southern California, so if you want us to install it, we can do that as well. Thanks
  4. Jun 15, 2017 at 10:11 PM
    boloson
    boloson New Member
    Is the install still the same as the 1st 2 bins but 1 long chunk to be cut out of the floor instead of 3 square cutouts?
  5. Jun 15, 2017 at 11:00 PM
    havasubud
    Earl
    Corona, California
    I am filming the install video next week. I will have it up on the site sometime late next week. Here is what you have to do, step by step.
    1Disconnect battery
    2:Remove rear seats from truck by removing the 8 17mm bolts from the seat frames.
    3:Remove driver side and passenger side door sill panels
    4:Remove driver side and passenger side outter seat belt lower bolt covers and remove 14mm lower seat belt bolts
    5:Remove driver side and passenger side lower c piller panels by pulling out on panel
    6Pull carpet back to expose foam subfloor and remove foam panels
    7:Remove the 14mm bolts from the two center seat rails
    8:Install new seat rails. They will be stamped 1 and 2. 1 is the passenger side and 2 is the driver side
    9:Temporarily reinstall foam subfloor panels. They will not fit now due to the new design of the rails.
    10Press down hard on the foam in order to mark the foam where it is contacting the seat rails
    11:Remove the foam subfloor and cut out the area of the foam so it clears the seat rails.
    12:Once trimmed, reinstall subfloor foam panels and reinstall the carpet, side panels, seat belt bolts and door sill plates.
    13Place cardboard template on floor and use two of the seat bolts to hold it in place
    14:Mark the carpet with a carpenters crayon
    15:Use a razor knife to cut the carpet out
    16:Once carpet is cut, use a linoleum hook knife to cut out the foam subfloor
    17Place seats back into truck but do not bolt down
    18:Guide long box into seat brackets(Be careful not to scratch the box at this point)
    19:Line up slot in floor of long box with threaded nut on seat rail and install the provided bolt and washer and tighten
    20:Reinstall seat bolts and torque to 34lbft
    21:Enjoy
    So it is the same as the other two but has more steps involved,
  6. Jan 4, 2020 at 10:31 PM
    2a_TX_Tundra
    2a_TX_Tundra New Member
    2020 SR5 CM TSS in Quicksand
    I know I'm digging up old post but did you ever get around to making that install video? If so do you have a link to it?
  7. Jan 5, 2020 at 2:20 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  8. Jan 5, 2020 at 7:00 AM
    2a_TX_Tundra
    You are awesome, thank you
    Pinay[QUOTED] likes this.
  9. Oct 19, 2020 at 6:00 PM
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    Has anyone installed this with the Husky full coverage mats? Obviously I will have to trim the mat as well. This may be a question for @havasubud
    Thanks
    -Edsel
  10. Oct 22, 2020 at 8:22 AM
    havasubud
    Earl
    Corona, California
    We have had several do it with the Husky or Weathertech. Unfortunately you will have to cut the mat because it will not sit right once the long box is installed.
    Damie Street[QUOTED] likes this.
  11. Oct 22, 2020 at 10:01 AM
    Damie Street
    Edsel
    South Carolina
    Thank you. I will be ordering one very soon
