New Denso with a bit of damage. Use or return?
Discussion in '2nd Gen Tundras (2007-2013)' started by e30cabrio, May 23, 2023.
  1. May 23, 2023 at 1:09 PM
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Radiator has been acting up, got a new OEM Denso.Should I be concerned about this?
    I was able to bend most of the fins back.
    [​IMG] [​IMG]
    __________________
    dondino likes this.
  2. May 23, 2023 at 1:13 PM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    I'm not too worried about the fins that you can bend back, but I don't like that bend on the core of the unit. I'd send it back and get a new one.
  3. May 23, 2023 at 1:14 PM
    You should be fine. Those fins bend easy so it's pretty common to stuff like that.
    Edit....I didn't notice the bend. I would request a replacement.
  4. May 23, 2023 at 1:23 PM
    AZBoatHauler
    So.Arizona
    This.
    e30cabrio[OP] likes this.
  5. May 23, 2023 at 1:40 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    No way would I use that. Get another one sent in.
  6. May 23, 2023 at 1:43 PM
    Return....
  7. May 23, 2023 at 1:44 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    I agree with the others...the fins are ok. but the bend on the side is not. Get a replacement
  8. May 23, 2023 at 3:07 PM
    e30cabrio
    Amazon is replacing it. Thanks!
    Johnsonman likes this.
  9. May 23, 2023 at 3:20 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That’s only foam tape make it look bent
  10. May 23, 2023 at 5:25 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I made the mistake of ordering denso on Amazon. 2 came in both were damaged. Return that thing and order at RockAuto.
    e30cabrio[QUOTED][OP] likes this.
  11. May 23, 2023 at 5:57 PM
    e30cabrio
  12. May 23, 2023 at 5:58 PM
    e30cabrio
    Nope, it's the frame.
  13. May 25, 2023 at 6:34 AM
    e30cabrio
    I argued with Amazon about not getting a replacement in a timely fashion so loudly they said keep it & have your damn money.
    I need a good radiator to go to L.A. at 3am tomorrow so I took the damaged radiator to a shop, they pressure tested it & found it good, tested mine & it's leaking, they installed the new one, I was running at 205 before pre overflow nipple breakage, now it is 190.
    I will order the CSF when I get back from L.A.
