new damage
Discussion in '2nd Gen Tundras (2007-2013)' started by ausei, May 25, 2015.
  1. May 25, 2015 at 8:52 AM
    ausei
    ausei [OP] New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    so noticed some damage to my hood and fender. dont know where it came from. also noticed this gasket is worn out...called toyota said it $17 for a new one. so it isnt bad hopefully its easy to install...IMG_0308.jpg IMG_0307.jpg
  2. May 25, 2015 at 9:15 AM
    greynolds2012
    greynolds2012 New Member
    Greg
    Mississippi
    2012 White TSS 4wd CM
    Leveling Kit, Interior LED Kit, LED Puddle Lights
    You can't have anything nice anymore
  3. May 25, 2015 at 9:16 AM
    Body shop for the hood (or buy the color matched paint and DIY if you feel comfortable with that)
    The gasket I wouldnt have a clue where to start, but I'm sure if i re-searched Google, and Youtube well enough I could figure it out....or if I asked my wife...because women tend to think they know everything. :D
    robie56 and tat2ude39 like this.
  4. May 25, 2015 at 9:32 AM
    Mike Tread lightly.
    south carolina
    Looks like that was done in a parking lot and someone used your truck to hold something.
  5. May 25, 2015 at 10:28 AM
    tuna813
    tuna813 New Member
    Tuna!
    13' RCSB
    Had similar on my Tacoma from a laundry basket. Mike's spot on
  6. May 25, 2015 at 10:31 AM
    Yea, Like at Home Depot. Temporarily stacked some bricks on your hood while they fumbled in their pockets for the keys to their Prius.
  7. May 26, 2015 at 3:50 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Yep. Had a similar set of scratches on the side of my Tacoma where some jackwipe leaned their crap against me while fingering their hole. I always park way the hell out in the nether regions of parking lots too, but even that didn't stop it from happening.
  8. May 26, 2015 at 8:28 AM
    ausei
    Ause
    Baton Rouge, LA
    yea. sounds true. gasket was easy. 17$ pull it off stick the other one in.
    Tchapman1998 likes this.
  9. May 26, 2015 at 8:45 AM
    Good deal on the gasket. Figured the dealer would jam you for $30.
  10. May 26, 2015 at 8:51 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Unless you use your truck exclusively on a farm or something, small damages are likely to occur. I just don't get bent out of shape. I usually park sufficiently away from heavily used lots. But I don't park way out there either. That's also asking for trouble.
  11. May 26, 2015 at 3:41 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    All i can say is ouch!
  12. May 31, 2015 at 12:42 PM
    tundratrav82
    tundratrav82 Nevada Tundras
    travis
    winnemucca, NV
    2011 tundra limited TRD crewmax
    Limmo tint on all 3 rear windows, 20% in front two. 18" black ballistic rims with nitto tires Bike bar in the bed for my dirt bikes..
    Have some on my truck too.. I think its from rocks or mud in the scrub brush at the local do-it-your self car wash..
  13. May 31, 2015 at 1:33 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I would agree with Tuna813, my daughter put some scratches like that on the trunk of her car by setting a basket of clothes there while she unlocked her car.I found it hard to believe a laundry basket could cause that much damage, but that was her story and she stuck to it!
  14. May 31, 2015 at 3:39 PM
    I have to drive thru a lot of sage brush on my property and it does wonders on the paint. Most scratches are superficial and wax out. Some don't. Same thing with my 09 Tacoma. Biggest gripe with Toyota is the paint finish or lack of.
  15. May 31, 2015 at 6:31 PM
    Schillout
    Schillout New Member
    2015 Sky Silver CM 4x4 Xp package
    De badge, TRD Pro grill with color match, P3 brake control with ESP install kit, Weathertech front and back
    2500 grit wet sand, polishing compound, wax, in that order. Make sure it's polishing compound not rubbing compound. Search YouTube for detailed instructions.
  16. May 31, 2015 at 8:30 PM
    2015TRSPROSD
    2015TRSPROSD 2015 Tundra TRD PRO
    2015 TRD PRO CREWMAX
    XPEL protective Film (XPEL.com) Whole vehicle Tundra stamped letter insert (black) TRD PRO bed stamp letter insert Punisher Hood Decal (Matte Black) Fender and side cladding (TrdSparks) Side steps (Iron Cross- Linex coating) Retrax Pro Bed tonneau cover (Black) Punisher skull hitch cover (color matched custom paint) Michelin Defender LTX MS 295/70/18 Toyota Tundra 14-15 LED Taillights - Dark Red Smoked Lens Opt7 Headlights (bright as the sun pure white light) Tundra center console decider TRD Cold Air Intake Stubby antenna Weather Tech all weather mats TRD Brake pads Titanium exhaust wrap (covers exhaust pipes) Painted Engine Cover (Color Matched) Optima battery Billet Aluminum Optima Battery cover (Skull design-Optimatrays.com) TRD Sway Bar Kit Headlight Revolution (Gen 2 fog lights) Headlight Revolution Stealth light bar Color stable window tint Door sill protective trim Drivers side Grip Assist Hamdle add on LED bulbs inside & outside placements Focal front speakers and tweeters Kicker rear speakers JL stealth box subwoofers Kicker 4 channel amp Kicker mono amp Rebadged Whole
    I put Xpel clear bra film on whole truck not rock chips no scratches and it self heals swirls marks at 74 degrees and above if it's painted it's covered even wheel wells
