New Coachbuilder Front Bump Stops
Discussion in 'Ekstrom Design' started by Coachbuilder1, Aug 23, 2024.
  1. Aug 23, 2024 at 9:26 AM
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
  2. Sep 1, 2024 at 7:40 PM
    VUDUBLU
    VUDUBLU New Member
    David
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Would I need two sets for the front?
    Also, any plans for rear bumpstops in the future.
  3. Sep 1, 2024 at 10:22 PM
    blenton
    blenton New Member
    What does “out preforms your factory bump stops..” mean?? Per the website description… :boink:
    Coachbuilder1[OP] likes this.
  4. Sep 2, 2024 at 4:30 PM
    Coachbuilder1
    David
    Salt Lake City UT
    ( Tundras 2007-2021 have 2 bump stops on each side ) The bump stops on the front side of frame touch before the rears will and can honestly use one set if you're not off-roading heavy and have not added addition weight. If you've added weight and want to extra protection its worth upgrading front and rears.( 2 Sets )
    We are designing rear options and will have them available later this year.
    (Tundras 2022+) only have one per side.
    VUDUBLU[QUOTED] likes this.
  5. Sep 2, 2024 at 4:38 PM
    Coachbuilder1
    David
    Salt Lake City UT
    The factory bump stops only have about .625" of material that can be used to slow down up travel or avoid over cycling resulting in bottoming out. Our Bump Stops have 1.875" of material allowing much more control during up travel without the harsh (slam) you have with the factory set. full protection without feeling anything. :oldglory:
    VUDUBLU likes this.
  6. Sep 2, 2024 at 4:50 PM
    blenton
    blenton New Member
    You are missing the point. It reads ‘preformed’ as in, formed beforehand, when I can only assume you meant to say ‘performed’ as in the performance, or the measure or the ability to do something.
    I was politely ribbing your lack of proofreading skills…
  7. Sep 2, 2024 at 4:55 PM
    Coachbuilder1
    David
    Salt Lake City UT
