New amp fixed crappy JBL system
Discussion in 'Audio & Video' started by Grimm1, Mar 7, 2018.
  1. Mar 7, 2018 at 3:10 PM
    Grimm1
    Grimm1 [OP] New Member
    I had a new amp installed in my 2018 tundra 1794 edition and it fixed the crappy JBL system. Yes I kept all the factory equipment adding that amp makes it sound like a great system. The amp and install only cost me $100 well spent considering what one pays for a tundra
    PowayDave, Sas, trayday and 6 others like this.
  2. Mar 7, 2018 at 3:16 PM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Which amp did you get?
    Pudge likes this.
  3. Mar 7, 2018 at 3:22 PM
    Grimm1
    I bought the Harman Kardon 1000 watt. Well worth the money system sound spactacular
  4. Mar 7, 2018 at 3:54 PM
    synackattack
    synackattack New Member
    Bradenton, FL
    2018 Cement Limited CM TRD Offroad 4x4
    I wondered if all it needed was more juice. Do you have any pics of the install?
    I haven’t looked in to it at all but I think my system has a factory amp...did you just replace that?
    Thanks!
  5. Mar 7, 2018 at 3:56 PM
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    I don't believe you can just replace the factory amp since it "decodes" the output from the head unit. I think you have to place the new amp after the factory JBL amp.
  6. Mar 7, 2018 at 4:00 PM
    Grimm1
    Sorry no pics . I just had them bypass the factory amp. With the cardon 1000 watt amp. And yes I figured it needed more juice and it worked very well i left the factory amp in so when it comes time to trade the truck in it can be put back to factory without any problems. Highly recommend
  7. Mar 7, 2018 at 4:03 PM
    synackattack
    Bradenton, FL
    Great. Well it’s worth a shot before trying replace everything.
    Thanks for sharing!
  8. Mar 7, 2018 at 4:06 PM
    Grimm1
    No need to replace the system can handle a lot more than what I added but it does sound great. And your very welcome.
  9. Mar 7, 2018 at 4:22 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Wait what? Everything ever written and said about the JBL system states adding an amp is not possible. Well it's not that simple anyway.... We need details on this
    Sas, SGTSMOKDU, Black Wolf and 2 others like this.
  10. Mar 7, 2018 at 4:24 PM
    Pudge
    CT
    You didn't need a line out converter ? What are the specs on this amp? This makes zero sense to me, I want it to, but after a year of research on how to upgrade the JBL on the cheap it makes so sense.
    Okie1, 1UPPER and Black Wolf like this.
  11. Mar 7, 2018 at 4:41 PM
    Wutachampion
    Wutachampion New Member
    DFW
    used to own - 2016 MGM SR5 CM Texas Edition
    Yeah or a diagram of some sort with outputs and inputs would be helpful
    If it’s that simple I can’t imagine why no one considered it previously ??? :/
    Pudge likes this.
  12. Mar 7, 2018 at 4:42 PM
    Grimm1
    It is actually very simple. they just bypass the factory amp with the newer bigger amp. And leave the factory amp right where it is. and the install only took an hour. So yes it is possible. Lol.
  13. Mar 7, 2018 at 4:43 PM
    Grimm1
    I had mine done at a local install company
  14. Mar 7, 2018 at 4:44 PM
    Grimm1
    I didn't personaly install it.
  15. Mar 7, 2018 at 4:46 PM
    Pudge
    CT
    There are multiple installers and audio companies that have tried to come up with solutions to fixing the JBL system. Replacing the amp isn't the solution or even an option we need more information about this. If it was this simple then we'd all do it. Maybe things changed in 2018? But this really makes no sense to me or probably anyone who has a JBL system.
  16. Mar 7, 2018 at 4:47 PM
    Johnathand
    Johnathand New Member
    Johnathan
    16 Platinum
    I’ve been telling people this. The speakers are more than adequate. The whole issue was the amp. I ended up installing my whole system. But started with the amp and it sounded 100x’s better
    Sunnier likes this.
  17. Mar 7, 2018 at 4:50 PM
    Pudge
    CT
    All you had to do was reolace the amp?
    What about a sound processor and line out converter? Every bit of literature says that the amp on the JBL acts as much more than an amp. I'm not calling anyone a liar here. I just wanna know details. I couldn't find a solution to fix mine for under 700 and that didn't include changing any speakers. In fact I'd rather keep my speakers and head unit.
    CaptainGrumpus likes this.
  18. Mar 7, 2018 at 4:52 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Maybe OP can provide installer information so they can provide instructions?
    Pudge likes this.
  19. Mar 7, 2018 at 4:53 PM
    Grimm1
    The wiring in the 2018 is different than in previous years yes. I know that because of the remote start that I had installed. the remote started had to be a factory remote start
  20. Mar 7, 2018 at 4:54 PM
    Grimm1
    I had mine done at Elitecar and audio here in Tulsa oklahoma
  21. Mar 7, 2018 at 4:54 PM
    Pudge
    CT
    Seriously. It can't be this easy. I spoke at length with tech12volts, and its so complicated. Even taco tunes and OEM audio had to come up with an elaborate system.
    BTBAKER[QUOTED] likes this.
  22. Mar 7, 2018 at 4:57 PM
    Grimm1
    Seriously it was that easy. Just bypassed the factory Amp rewired everything to the new Amp. When needed can be switched back to the factory Amp.
  23. Mar 7, 2018 at 4:58 PM
    Grimm1
    No I didnt
  24. Mar 7, 2018 at 4:59 PM
    Grimm1
    Yes I did and like I said it was installed all for $100 and only waited and hour.
  25. Mar 7, 2018 at 5:03 PM
    Pudge
    CT
    Can you give more info? Like model number and specs of amp? And where it was installed?
    GNTundra likes this.
  26. Mar 7, 2018 at 5:09 PM
    Grimm1
    Its a cadence 1200watt high speed mofset supply studio grad output. Fully adjustable 12db
  27. Mar 7, 2018 at 5:10 PM
    Pudge
    CT
    Could it be this easy? I remember those amps from way back in the day.
  28. Mar 7, 2018 at 5:10 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Broseph, pull the seat and take a couple photos for us...this seems too good to be true! Plz?
    TheBeast and Pudge like this.
  29. Mar 7, 2018 at 5:13 PM
    Grimm1
    Sunnier and kcaustin66 like this.
  30. Mar 7, 2018 at 5:14 PM
    Grimm1
    Thats what's on the box of the Amp I had installed. Remember the factory amp has been bypassed
