New agm battery
Discussion in '2nd Gen Tundras (2007-2013)' started by Scotidont, Oct 27, 2018.
  1. Oct 27, 2018 at 7:36 AM
    Scotidont
    Scotidont [OP] New Member
    Scott
    2008 tundra 5.7
    My battery recently went out. The parts guy talked me into the new AGM battery. 4 days later me 4 mo old starter goes out.. Ca mb the new battery be the cause?
  2. Oct 27, 2018 at 7:55 AM
    Welcome.
    No. Did you install the battery?
    Just wondering if some leads or tools arced out....
  3. Oct 27, 2018 at 10:13 AM
    Welcome from Ohio!
    No the battery isn't the problem.
  4. Oct 28, 2018 at 9:19 AM
    Dr_Al
    Dr_Al New Member
    Al
    One of the worst things for a starter is a weak battery. Did your old battery just die or was it getting weaker and weaker which in turn meant the starter was turning slower than normal? Electric motors have a number of coils inside them. As the starter turns it turns on a pair of coils to force the motor to turn. When spinning slowly the motor is stronger but the current also is turned on longer. The longer the current is turned on the more the coils heat up. Where as if it's spinning faster the coils turn on then off. It's also why they say not to try and turn your car over for too long of a time and to let it rest after using the starter for more than a few seconds. The heat will damage the electrical insulation on the wires in the coils, the electrical brushes, and the solenoid. Of course if your old battery died then your starter dying could have just been from use.
    Cobshop likes this.
