New 6 lug wheels and 4Runner tires on Gen 1?
Discussion in '1st Gen Tundras (2000-2006)' started by ToyotaJim, May 23, 2020.
  1. May 23, 2020 at 3:42 PM
    ToyotaJim
    ToyotaJim [OP] New Member
    My 2002 Tundra (non-lifted, 2WD) came with tires that are soon going to need replacing, so I'm weighing options. It wears stock size on aftermarket rims, which are very handsome. But the tires are old, but still serviceable, 245/70/16. It's the 6 lug pattern rim. I believe these are the same as all modern 4Runner patterns. Pricing out new tires, looking at $200 each, so $800 + if you want a spare... (My spare is the original, and obviously trash at 18 years old.)
    I have a set of summer takeoffs from my 4Runner, and also looking around at the very low priced take offs that others seem to commonly repeatedly do. A whole new set with rims mounted and balanced can be had for $400-500 usually, and I actually like the rims! These are generally around 265/70/17s. It's a no-brainer if they fit to grab a good set of takeoffs.
    The question is 2-fold.
    1. I believe the rim fits, but can anyone confirm?
    2. Will at 265/70/17 fit the Gen 1 Tundra without causing problems, or terrible performance isues?
    Thanks!
  2. May 23, 2020 at 10:02 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    With that tire size you shouldn't have a problem. Chevy GMC truck rims fit the tundra also except that the center bore is a like 2 or 3 hairs smaller, usually not an issue.
    ToyotaJim[OP] likes this.
  3. May 24, 2020 at 4:16 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    OEM GM 6 lug wheels have a center bore of 78mm, Toyota is 106. That's more than an inch difference. There's no way they'll fit without significant machining.
    Yes, the rims will fit.
    I have no first hand experience with that size -- mine are stock for a 4WD model: 265/70-16.
    FWIW: 265/70-17 (31.60") is essentially equivalent to 265/75-16 (31.64") which I know some here are running. I'm pretty sure I could fit an additional inch in the wheel wells of my truck with its stock suspension. When I need new tires, I plan to go with 265/75-16 so I can get an E Load Rated tire. Not sure if 2WD is different though.
    ToyotaJim[QUOTED][OP] likes this.
  4. May 24, 2020 at 4:28 AM
    aggrex
    aggrex New Member
    PA
    Tundra AC SR5
    Running 265/70R17 with slight rub on front splash guard backing up while turned. I expect in time the rub should go away.
    N84434 likes this.
  5. May 24, 2020 at 5:06 AM
    Hooptytrix
    Dirty South
    Many of the aftermarket rims for GM/Chevy also fit the Tundra except for the bore size is usually a bit smaller. If you shop the faceless marketplace, craigshoehouse etc. You might trip over a nice deal for used wheels and tires and adding aftermarket wheels from GM to your search opens up many more opportunities. Just be sure to test fitment before you commit.
    My bad though, I should be more specific sometimes. I was thinking aftermarket but didn't type it
    aggrex and tvpierce[QUOTED] like this.
  6. May 24, 2020 at 5:11 AM
    Hooptytrix
    Dirty South
    Harbor freight heat gun. See where it's rubbing and heat the plastic area up, then gently reshape it.
    Truck Lookin good
    aggrex[QUOTED] likes this.
  7. May 24, 2020 at 7:14 AM
    NWPirate
    Zach
    WA
    This might not be any help because it's on a 04 4wd Sequoia but here ya go anyway. 265/70R17 4Runner takeoffs. Zero rubbing for me, good luck!
  8. Jun 9, 2020 at 12:12 PM
    AncientTundra
    AncientTundra New Member
    2000 Tundra Limited
    I have a 2000 Tundra with the “snowflake” 4Runner rims, as seen in my profile pic. I am running 265/70/17 with no issues. Stock ride height.
  9. Jun 9, 2020 at 1:48 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I ran 4-runner rims on my 2000 Tundra until I sold it recently. Good looking rims, but the offset was slightly different, so the overall track width was reduced a bit.
    I don't recall for sure, but I think I tried a set of Pirelli's in 265/70/17 and they rubbed. (remember - different offset). I wound up sticking with a 245/70/17. This was ~6 years ago, and my memory isn't what it used to be.
    https://www.tundras.com/threads/lets-see-1st-gen-with-toyota-rims.40487/page-13#post-1771576
    post 363 is my old truck on 4 runner sport rims.
