NEW! 22+ Toyota Tundra LED Tail Lights | Form Lighting
Discussion in 'Lighting' started by Form Lighting, Apr 15, 2025.
  1. Apr 15, 2025 at 6:51 AM
    Form Lighting
    Form Lighting [OP] New Member
    2007-2019 Tundra
    Our all-new LED tail lights for the 2022+ Tundra are here—built for a tougher look with aggressive smoked lenses, high-output reverse lighting, and a premium startup sequence with sequential turn signals. With clean, flush fitment across all trim levels and true plug-and-play installation, this upgrade delivers both style and function with no hassle. Preorder today and be one of the first to bring the new look home!
    Choose from two lens options—Smoked or Red—to match your Tundra’s style. The smoked option is designed with tinted optical components, which provides a factory-quality smoked appearance, while the red option features a vibrant red lens design for a true OEM style.
    These Tundra tail lights are packed with modern features, including a startup animation that is sure to turn heads, no matter what trim you have. Anytime the running light turns on, the lamp will illuminate in a smooth chasing sequence, followed by a pulse.
    These tail lights feature additional high-output LED reverse lights, giving you double the number of reverse lights and significantly improving visibility when backing up at night.
    https://www.youtube.com/watch?v=jUQ-84uNMfA
    Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. Any warranty or service needs are supported directly with fast US-based support, and any replacement parts, if needed, are shipped quickly from our US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
    Do you have any additional questions? We would be happy to help!
    Are you a US forum member? DM us for a FREE shipping code!
    —Form Lighting Team
