Poll - New 2022 Tundra Owners Please Post Comments on Real World Mileage
Discussion in '3rd Gen Tundras (2022+)' started by borla123, Dec 22, 2021.
Gas Mileage Expectation Gen 3 Tundra ? 17-city / 22 hwy /19 cmb (Votes can be changed later)
  1. I am achieving EPA ratings
    27 vote(s)
    27.8%
  2. I am not achieving EPA ratings
    70 vote(s)
    72.2%
  1. Jan 15, 2022 at 8:28 AM
    #211
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    I’ve seen and experienced the same and my commute is roughly the same. The mpg have been disappointing for sure. Of course you get those, what do you expect from a truck, guys. Well, I expected what what was advertised or at least within the range. I have 1800 miles so far and right now I’m sitting at 16.9
    I’ve even tried a whole tank in eco mode and it was the same.
    Monsterson and RavingOx like this.
  2. Jan 15, 2022 at 8:38 AM
    #212
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Eh. One other explanation I had in mind is how the transmission logic changes over time to maximize mileage (mostly by lugging the engine and shifting early).
  3. Jan 15, 2022 at 8:48 AM
    #213
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    By the time you put gas in the tank, some junk in the cab and bed, and a couple passengers, you are still approaching 3 tons in a brick shaped vehicle. This is just not a recipe for good MPG regardless of engine. Just my 0.02.
    Terndrerrr likes this.
  4. Jan 15, 2022 at 8:50 AM
    #214
    raylo
    raylo not so new member
    Frederick, MD
    None
    Not looking for good. Just looking for acceptable. That may vary individually for potential customers.
    Rwaters likes this.
  5. Jan 15, 2022 at 8:52 AM
    #215
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I get 21 mpg at 60 mph. And 18 at 70mph in temps in the 30’s. Stop and go and any uphill that involves turbos really tanks the mileage. On my old truck I can go pedal to the floor on stop and go and it wouldn’t really affect anything , not the case with this truck. My first tank was 17.6, second was 19.6..those are tank calculations at the pump. Today I will compare the dash mileage to the pump calculation after using only non ethanol to compare.
    I have to think people getting below advertised mileage just have a particular drive not conductive to good mileage or they push the peddle down to much. I have been following Toyota’s recommended break in procedure. Idk if its necessary but why not.
    Terndrerrr, Acedude, =JSG= and 3 others like this.
  6. Jan 15, 2022 at 8:53 AM
    #216
    raylo
    Frederick, MD
    None
    That's not all that bad with cold starts/warmups (depending on where you are) and winter blend gas. It should improve a bit after the switchover to summer gas.
  7. Jan 15, 2022 at 8:58 AM
    #217
    xc_tc
    xc_tc New Member
    That’s not true. The shift points are fixed and don’t change over time. The learning the transmission does is for the wear and tear on the fluid. It adjusts the oil pressure needed for shifting as the oil ages.
    One thing this Tundra may have that the Lexus LS and LC 10-speed units have are adaptive control logic which hold lower gears longer based on your driving. If you’re an aggressive driver, the 10-speed will hold lower gears and drop your fuel economy due to higher revs.
  8. Jan 15, 2022 at 10:33 AM
    #218
    HBV2017
    HBV2017 New Member
    That is what the meter is showing. The meter in my 2020 seemed pretty accurate compared to the calculated fuel economy, so I’m just going off of that. I’ll try calculating my next tank and see if a variance exists.
  9. Jan 15, 2022 at 12:28 PM
    #219
    Totherion
    Totherion New Member
    My story is a lot different.
    I had a brand new F-150 with a 2.7 Ecoboost. Nice truck but guzzled gas like you wouldn't believe. I was getting 9 to 11 mpg.
    Took it to the Ford dealer. They said the 2.7 needs a few thousand miles to break in and they promised mpg would improve.
    After about 4000 to 5000 miles the mpg started to climb dramatically. I got 19 to 23mpg average. Fantastic engine but oh my the first few thousand was awful.
    TK1979 likes this.
  10. Jan 15, 2022 at 1:47 PM
    #220
    Rwaters
    Rwaters New Member
    That’s what I’m hoping for. My Silverado took about 5k miles before the mileage got up to a constant 20mpg (19 after leveling kit). The next tank I’m going to use ethanol free, just out of curiosity.
    TK1979 likes this.
  11. Jan 15, 2022 at 1:58 PM
    #221
    sd172
    sd172 New Member
    South Dakota
    Your 2.7 is a lot closer to the new 3.5 in terms of technology. Hopefully the mpg improvement is common across the board.
  12. Jan 15, 2022 at 2:11 PM
    #222
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    So much discussion, too little MPG data.
    Turd gen people- please keep reporting your MPG after calculating at the pump. Lots of us are curious.
    DeesCrewMax and Abos like this.
  13. Jan 15, 2022 at 6:10 PM
    #223
    xc_tc
    xc_tc New Member
    Reset it next time you fill up. You can also change it to show tank average mpg (reset at each refuel) and trip average (reset after each shutdown). I’m curious to see what others are seeing too.
  14. Jan 15, 2022 at 6:49 PM
    #224
    Rwaters
    Rwaters New Member
    I’m averaging 16.9 right now with about 100 miles until empty. That’s by meter so far. My last tank averaged 16.9 as well. I’ve been trying to drive as economically as possible. My drive to work is mainly rural with some city and idle time, which is approximately 80 miles round trip.
  15. Jan 15, 2022 at 7:12 PM
    #225
    Toyota1234
    Jack
    17.8 mpg mixed driving on my last tank. What kind of mixed driving? Who cares it doesn’t mean anything. I can empty a tank and get 14 mpg or I could empty a tank and get 23. Point is I CAN get 23. I think that’s the point of this thread. Do these trucks get the mileage as advertised? Yes. Can you drive in ways that get worse then advertised? Yes.
  16. Jan 15, 2022 at 7:12 PM
    #226
    samwell885
    samwell885 New Member
    2022 Limited 4x4
    Drive mine home 90 miles from the dealership and it was 21-22 MPGs the whole way (mostly highway). I’m sure I can keep it close to there or get 8 MPGs on a whole tank by driving the shit out of it.
    =JSG=, mountaingroan and Toyota1234 like this.
  17. Jan 16, 2022 at 5:45 AM
    #227
    borla123
    borla123 [OP] The Pits
    Ontario
    18 Tundra TRD OR - 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    The point of the thread is to help people understand what kind of mileage it is getting when you use it as a commuter daily driver vehicle, and as the truck was intended; loaded and or towing something. I mean, the later is what Toyota seems to be preaching in the new commercial I saw of the MGM color truck during the football game last night.
    So Please specify.
    1) Daily driving, commuter empty
    2) loaded down - let us know how close to the payload rating
    3) towing - how much weight you are towing.
    The OP text modified.
    If one of the three categories is not listed I will assume you are using it as a daily driver, commuter truck and it is empty. I am interested in the mileage for all three categories and appreciate all input. thank you
    Mattedfred, Acedude and raylo like this.
  18. Jan 16, 2022 at 6:09 AM
    #228
    oxlsu40
    oxlsu40 New Member
    2022 Black SR5 4x4
    I'm getting 18-20 mpg per tank with 1k miles driven. 295/60/20 Nitto Recon Grapplers on stock height. Mix of city but mostly highway going 65-70 mph. All in normal mode.
  19. Jan 16, 2022 at 6:47 AM
    #229
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    When?? You mean "If"
    Totherion[QUOTED] likes this.
  20. Jan 16, 2022 at 6:55 AM
    #230
    Toyota1234
    Jack
    My cousins ecoboost improved a bit after a few thousand miles. If this truck gets better then I’m all ready getting I’m going to be pretty happy. All though I won’t know until next winter. Knowing it will improve into the summer.
  21. Jan 17, 2022 at 8:59 AM
    #231
    Rwaters
    Rwaters New Member
    So I filled up today with 90 octane ethanol free, so we’ll see if that’s any different. I ran it as low as I could before filling up. This last tank on normal mode I got 16.8 mpg based on truck, math showed 16.77 mpg so it’s a wash.
    JLS in WA and sd172 like this.
  22. Jan 17, 2022 at 12:58 PM
    #232
    Toyota1234
    Jack
    I have been putting in non e the last two tanks. I burned 10 gallons of it last week and I got 17.8 hand calculated and the truck screen showed 17.2. My Tacoma consistently got about 1.5 mpg better with non-E. I wish there was a way to calibrate these trucks like you can after market fuel gauges.
  23. Jan 17, 2022 at 1:24 PM
    #233
    Rwaters
    Rwaters New Member
    Funny you say that, in the short 40-60 miles I’ve put on this tank I’m getting 19 mpg. I assume once I get to the end I’ll be getting 17 or so, which isn’t worth the extra cost. Then I’ll use non E once a month or so.
    how many miles do have on yours?
  24. Jan 17, 2022 at 1:30 PM
    #234
    ja5er
    ja5er New Member
    New York
    1500+ miles, it’s cold here so a bit of warming up in the morning for the kids. I’ve run MPG over a few tanks, partial fills, full fill, etc… to see what it gets on highway and mixed. I’m expecting to constantly see 17+ with my driving going forward, but more micro numbers:
    Avg with mixed driving - 17
    Highway - 21-22
    Beating only around town - 16
    essentially the truck is good on the highway doing about 65-70. Above that the mileage starts to tail off. Around town, it didn’t matter, 16-17 consistently.
    Totherion likes this.
  25. Jan 17, 2022 at 1:43 PM
    #235
    Totherion
    =JSG=, Mattedfred and rideandfly like this.
  26. Jan 17, 2022 at 5:03 PM
    #236
    Toyota1234
    Jack
    Just broke 1000 miles. Your dash isn’t likely going to show an accurate number make sure to hand calculate to compare. I did the math once and it was something like if you get 1.5mpg better with non ethanol then as long as it’s not more then 60 cents a gallon it’s cheaper.
  27. Jan 17, 2022 at 5:06 PM
    #237
    Toyota1234
    Jack
    He said 24.5 mpg total. A 91 mile trip is hardly a accurate way to test mileage but it is interesting. I have gotten as good as 22 but have yet to drive at temps above 45.
  28. Jan 17, 2022 at 5:38 PM
    #238
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    One test is hardly a good assessment of mileage. I was hoping he’d come back and say that he’d run the test multiple times. I can get in the 20s with some chill driving downhill but currently hovering around the mid 16s. Only in my second tank and I’m at 5k ft and hasn’t been warmer than mid 40ºs.
  29. Jan 17, 2022 at 6:25 PM
    #239
    Totherion
    You're right. I made a mistake.
    I am betting it was an early click off. He should have done two clicks per fill.
  30. Jan 17, 2022 at 6:51 PM
    #240
    Toyota1234
    Jack
    The other day I was filling up and the truck clicked off 4 gallons shy of full..
