New 2020 Tundra whine/whistle noise
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Chris31909, Mar 21, 2020.
  1. Mar 21, 2020 at 6:32 PM
    Chris31909
    Chris31909 [OP] New Member
    2020 Tundra TRD Pro
    None
    Hello to the forum.. longtime reader but just joined so I could post about a weird noise I hear from the engine compartment while I’m sitting in park and giving the engine the slightest of revs. Sorta like a high pressure whine or whistle that from the naked ear while the wife was revving it for me it sounded like it was coming the the power steering pump area. Truck has 360 miles on it so would this noise be considered normal. I’m aware of the higher than normal valve train noise these trucks make but this is different. It’s either like the power steering pump is building and releasing pressure as the revs come and go. I’ll attach a link to video so maybe y’all can have a listen and see if it’s normal to be heard. Thanks!
    https://youtu.be/-sxfGMKcrpQ
  2. Mar 21, 2020 at 6:46 PM
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    Hard to tell from your video but if it helps mine makes a slight whistle at low revs also. Pretty sure its normal though. I was assuming it was from the throttle body
  3. Mar 21, 2020 at 7:06 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    Yeah I’ve heard about the notorious throttle body whistle dye to the mesh in the gasket but this sound with your head down near the engine it seems to come from the power steering pump area, like the pressure builds up when you open the throttle but soon as you let off the throttle it goes away. It doesn’t make this noise at all long as it’s sitting and idling, all you hear is the normal valve train noises that’s typical of the tundra engines. You can hear it best during the last half of the video kinda like it’s squealing inside the pump when I touch the pedal a little and rev it. It also is very intermittent as it doesn’t have this squeal all the time. It comes and goes as sometimes I can give it small revs and it not make the noise, then it will suddenly start as I feather the throttle. I just noticed it today while I was sitting in it and decided to enjoy the sound of the engine and exhaust in the driveway, and I noticed sometimes when I pressed the gas it would emit this weird squealing/ high pressure relieving sound and I started to get it to replicate it so I started video to see if I could capture the sound
  4. Mar 21, 2020 at 7:19 PM
    Welcome from NY.
    Do you have the TRD cold air intake? Could be coming from there.
  5. Mar 21, 2020 at 7:32 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome from Ontario Canada
  6. Mar 21, 2020 at 7:43 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    It’s all complete stock, it looks to have a pretty basic intake with the regular filter inside it so I would say no it’s not that TRD intake system I’ve seen installed in other tundras
  7. Mar 21, 2020 at 7:52 PM
    Okay . Could it be the air accelerator?
  8. Mar 21, 2020 at 8:21 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    not saying it couldn't be but it doesn't sound like its coming from the fender area, its more concentrated near the power steering pump/ alternator area of the engine far as I can hear it....here is another video to listen
    https://youtu.be/GeTQ3AF0Oyk
  9. Mar 21, 2020 at 8:42 PM
    Chris31909
    2020 Tundra TRD Pro
    None
  10. Mar 22, 2020 at 10:27 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Dude, if it concerns you, and it only has a few hundred miles, take it back to the dealership. Stop worrying about it and let them figure it out. That's what they are there for. But when you get it back, I would wipe down all surfaces that were touched by anyone, door handles, steering wheel, shift knob, hood latch (inside & out). They will fix it, or tell you it's normal. There's enough stress around us all right now, you don't need to be stressed about your new truck. Hell, my truck might be doing the same thing, but I have not noticed it. Hope they figure it out for you. Stay safe, remain vigilant.
    AircareTundra likes this.
  11. Mar 22, 2020 at 10:31 AM
    Chris31909
    2020 Tundra TRD Pro
    None
    yeah I’m certainly not gonna stress it I was just curious if anyone else experienced this sound. It’s not having any negative effect on the truck so I’m just gonna keep an eye on it and once things get back to normal I’ll stop by the dealer and see what they say
  12. Mar 22, 2020 at 10:37 AM
    Pbed85
    Pbed85 New Member
    Pete
    MN
    2019 dbl cab limited cement
    Using the red trd filter makes a strange high pitched noise. Might be that??
  13. Mar 22, 2020 at 10:52 AM
    Chris31909
    2020 Tundra TRD Pro
    None
    this one is running just the normal stock white color filter in the box
  14. Mar 22, 2020 at 11:06 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    its brand new things will quite down as you put on miles
  15. Mar 22, 2020 at 7:13 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Perhaps it is this:
    https://www.youtube.com/watch?v=FiA_pGyyWlQ
    KERNEL_DALE likes this.
  16. Mar 22, 2020 at 7:18 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    yeah I've been watching tons of videos on the tube trying to see if anyone else weird noise comes close to mine, it is likely possible my ears are sensitive to the noise and I can even hear it fully stock, as I've heard most people don't hear it until they add a new higher flow filter to the system
  17. Mar 22, 2020 at 10:36 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 GMC Sierra At4x AEV
    That’s the fuel pump. Very normal. Your Truck is running strong.
  18. Mar 23, 2020 at 4:06 AM
    Bad Cow
    Georgia USA
    Went out for a drive yesterday, no radio, could hear only that beautiful throaty exhaust note, no whistle at all. Maybe it's just my OLD ears, but I don't hear anything other than the engine and exhaust note. No way I would cut away that wire grate at the throttle body intake. What if a leaf somehow got into your filter box? Or any foreign debris for that matter. It's there to prevent anything from being sucked into the engine. I realize it bothers some of you, but it's probably nothing to worry about.
  19. Mar 23, 2020 at 4:51 AM
    timsp8
    NY
    Sound can travel. It could be the mesh screen thing in the intake and it sounds like it’s coming from a different part of the engine.
    Or maybe your truck is giving you a hint that it needs a supercharger whine.
    Chris31909[OP] likes this.
  20. Mar 23, 2020 at 11:57 PM
    Chris31909
    2020 Tundra TRD Pro
    None
    glad to hear it sounds normal...just wouldn't guess fuel pump since its located on the fuel tank right?
    Bad Cow likes this.
  21. Mar 24, 2020 at 3:25 AM
    Bad Cow
    Georgia USA
    I doubt what you are hearing is the fuel pump, since it is located inside the fuel tank itself. Probably an intake sound instead. For now, just drive it like you stole it. Toyota will have your back if anything were to happen.
  22. Mar 24, 2020 at 7:07 AM
    TundraLaw
    Northern Nevada
    it’s the sound of the fuel pump to injector bud. Any tundra whistle when accelerating for the first 1/8 of pedal travel is that.
    if you want to complain about a little noise, go get a ram and see what noises you hear on that lol,
  23. Mar 24, 2020 at 11:00 AM
    Chris31909
    2020 Tundra TRD Pro
    None
    Im certainly not complaining, this wasn't the intent on the post. im just a new tundra owner and wanted to identify what noises the truck makes that would be considered normal. truck is running great with no issues. whether its some sort of fuel system or throttle body whistle and based on the responses I have chalked it up to a normal sound and not worried about it
  24. Mar 24, 2020 at 11:01 AM
    Chris31909
    2020 Tundra TRD Pro
    None
    yeah its an odd sound for sure but it hasn't stopped me from driving it as usual and its been running great
    Bad Cow[QUOTED] likes this.
  25. Mar 24, 2020 at 12:23 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    Hey everYtime is hear a sound that was t there before I freak out too...then calm down after. So your not the only one lmao
  26. Mar 24, 2020 at 12:59 PM
    Bad Cow
    Georgia USA
    Just like a NASCAR driver. When the car is running really good, they hear ghosts in the machine.
  27. Mar 25, 2020 at 7:54 AM
    TundraLaw
    Northern Nevada
    For sure! Didn’t mean to come off as a dick. I bought a ram 2500 Cummins, traded in my tundra, and got my tundra back shortly after they bought the ram back. Long story short, stick with Toyota. FCA is a pretty looking product, but terrible quality.
    Dad has a Ferrari California. Same thing— looks pretty and sounds great, but get in the driver’s seat and you notice the steering wheel emblem is glued on, and already falling off.
    YsoSeRiouS! likes this.
  28. Mar 25, 2020 at 7:56 AM
    YsoSeRiouS!
    NorCaL
    California is a beautiful car but I still prefer my favorite a 1999 355 spyder Ferrari in manual
  29. Mar 25, 2020 at 10:17 AM
    Chris31909
    2020 Tundra TRD Pro
    None
    oh no worries man I just wanted to clarify that. I do know very well about those FCA vehicles as I just traded in my Jeep SRT for this Tundra. Less than 20k miles it needed an entire brake job and with those Brembo brakes the parts alone was gonna cost over 3k, so I said hell no and got rid of the Jeep lol. I decided on a Toyota because of the quality and reliability. FCA sure knows how to shine a turd lol
  30. Apr 6, 2020 at 5:19 AM
    Erniec21
    Erniec21 New Member
    2020 White Tundra TSS Off-road
    I searched “whistle” in the search bar hoping someone else was hearing a whistle noise when they barely accelerated lol good to know I’m not the only one hearing things lol I got my new tundra a couple weeks ago and just started noticing it like last week lol
