New 2001 Owner!
Discussion in 'New Member Introductions' started by Shellback, Oct 10, 2018.
  1. Oct 10, 2018 at 5:19 PM
    Shellback
    Shellback [OP] New Member
    Pink/Silver 2001 Tundra TRD
    Peeling door window trim.
    Hello!
    Just picked up a 2001. I know so little about the truck I will be picking your brains shortly.
    What I do know...
    - 2001
    - 200K miles
    - Limited TRD Access Cab 4X4
    - Color? I have no clue! Its like silver/gold?
    - Interior is tan leather.
    - Zero history! I know nothing on this truck's past maintenance but I feel pretty confident doing some work. I have some tools, work space, and time to do preventive work
    It's a bit rough but I needed a truck that wouldn't cost a lot. We are renovating our house and our cars have been trashed carrying lumber, tiles, wood flooring, etc.
    Anyway, I will post photos shortly.
    In the meantime, I need to address a hard steering wheel feeling with buzzing noise as you turn. Sounds like a P/S pump is either short on fluid or ready to go out.
    My first 2 questions for the group:
    1) Can you recommend an OEM or good parts suppliers to purchase parts online?
    2) Is there an online catalog/parts schematic to do research and identify parts/part numbers.
    Thanks!
  2. Oct 10, 2018 at 5:21 PM
    Blueknights75
    Ron
    Clayton, NC
    @Roman is our OEM Parts Supplier and is the best!
    Welcome from NC! Post some pics!!
    MotoTundra, Roman and Black Wolf like this.
  3. Oct 10, 2018 at 5:35 PM
    Welcome from Colorado. :worthless:
    Shellback[OP] likes this.
  4. Oct 10, 2018 at 5:38 PM
    Welcome from NY.
  5. Oct 10, 2018 at 5:38 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
  6. Oct 10, 2018 at 5:41 PM
    Shellback
    I know...pics coming soon.
  7. Oct 10, 2018 at 5:46 PM
    Professional Hand Model
    Hand Protectors
    Try changing the fluid yet? That sometimes helps. You can do the turkey baster change a little at a time.
  8. Oct 10, 2018 at 5:50 PM
    Is your power steering canister low on fluid? If so add some to at least eliminate that issue. Sorry, I now see you mentioned you were going to post pics. You are lucky because there are quite a few 1st gen owners here that can help you out. Definitely a great project truck with many more miles on it! :thumbsup:
  9. Oct 10, 2018 at 6:03 PM
    Welcome!!
  10. Oct 10, 2018 at 6:03 PM
    Welcome from Texas
  11. Oct 10, 2018 at 6:04 PM
    Hand Protectors
    Dexron II/III FLUID. Same as the transmission fluid.
  12. Oct 10, 2018 at 6:04 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA.....:)
  13. Oct 10, 2018 at 6:04 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  14. Oct 10, 2018 at 6:04 PM
    Welcome from Ohio!
  15. Oct 10, 2018 at 6:21 PM
    Shellback
    I feel very welcomed already. Thank you very much!
    I will check the fluids tomorrow AM. Had a long day searching for a sub $5K truck.
    Speaking of fluids, is this model finicky with using only factory fluids? Some car makers require only factory fluids and was wondering if it was the same case here.
  16. Oct 10, 2018 at 6:37 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  17. Oct 10, 2018 at 6:57 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  18. Oct 10, 2018 at 7:22 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from NorCal.
  19. Oct 10, 2018 at 8:04 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  20. Oct 10, 2018 at 8:41 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  21. Oct 10, 2018 at 9:51 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  22. Oct 10, 2018 at 10:51 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
    GNTundra likes this.
  23. Oct 12, 2018 at 5:37 AM
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Welcome from Buffalo!
  24. Oct 12, 2018 at 9:24 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  25. Oct 13, 2018 at 12:43 PM
    Shellback
    That did it. Thank you very much. Just topped it off. I do want to flush the system as it looks pretty yucky. Will be my first to-do maintenance this w/e.
    Casper421 likes this.
  26. Oct 13, 2018 at 1:34 PM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  27. Oct 15, 2018 at 8:06 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I will echo Roman from Toyota Of Cool Springs.
    Welcome to the forum!
  28. Oct 15, 2018 at 8:43 PM
    Shellback
  29. Oct 16, 2018 at 6:02 AM
    Notachickmagnet
    Notachickmagnet New Member
