Never seen this before not tundra related
Discussion in 'Off-Topic Discussion' started by Yota707, Jul 6, 2022.
  1. Jul 6, 2022 at 10:57 AM
    Yota707
    Yota707 [OP] New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Hey guys I bought a project car and I’m in the process of rebuilding the heads. It’s a 06 5.7 charger. I noticed when I removed the heads it looks like the rear water jacket one both sides have dirt in them. Have you guys ever seen this before?
  2. Jul 6, 2022 at 11:05 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Any issues with it running hot when it did run?
    Could be old radiator stopleak that’s dried out and nasty and made it’s way all through the cooling system. Might explain why you had to redo the heads :anonymous:
    1lowlife and Yota707[OP] like this.
  3. Jul 6, 2022 at 11:16 AM
    Yota707
    David
    Bay Area
    2015 Tundra TRD
    It was running fine but these cars are commonly dropping the valve seats. So in the process of doing that I noticed this. Would you recommend cleaning that out? It’s on both sides passenger and driver.
  4. Jul 6, 2022 at 12:00 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I was going to say bars leaks or some other cooling system stop leak. I would clean all that you can see.
    Yota707[OP] likes this.
