Neutral Transfer Case Selection
Discussion in '2.5 Gen Tundras (2014-2021)' started by ScarletSSpyder, Jun 13, 2019.
  1. Jun 13, 2019 at 7:22 AM
    ScarletSSpyder
    ScarletSSpyder [OP] New Member
    Sorry if this has been answered before (searched for a while and couldn't find an answer for the 14+ models), but is there a way to shift the transfer case into neutral? If not, is the only way to safely tow the vehicle on a flat bed? All my previous 4WD vehicles gave you the option to shift the transfer case into neutral (usually between 4H and 4L.
    Thanks!
  2. Jun 14, 2019 at 6:53 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    I will bump you on this one.
    First answer is no unless Borg Warner considers the 2014 and up 2L position similar to a neutral, I do not.
    Second is towing is all wheels off the ground for any distance unless emergency or unable.
    Good luck
  3. Jun 14, 2019 at 6:55 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Silly question,
    Have you read the owners manual for proper towing by chance?
    Welcome to the forum
