Neutral Saftey Switch P1780
Discussion in '1st Gen Tundras (2000-2006)' started by Spread5150, May 10, 2025 at 8:15 PM.
  1. May 10, 2025 at 8:15 PM
    Spread5150
    Spread5150 [OP] New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
    I got this code today.
    The truck drives fine.
    Suggested part for code P1780 was the Neutral Saftey Switch.
    Truck starts in park. In reverse the trucks rear lights kick on as they should.
    Any other way I can diagnose my check engine light ?
    Is it possible I slapped it into park and only got half way into park and locked it. I have a remote start on the truck (which I’ve had for a while ). So I’m thinking I started it in its halfway position.
  2. May 10, 2025 at 8:21 PM
    shifty` In South Dakota Trouble ain't hard to find
    Yes. Diagnostics are in the FSM. Link to download the FSM is in the megatrhead, but by now you should already have a copy saved on your hard drive. Search for the 5-digit code string, and get crackin’.
  3. May 11, 2025 at 7:37 AM
    Spread5150
    Dave
    Ok good news. Doing my own diagnostic with videos I found online and a hunch I had about when it started I got it solved.
    From the time the light turned on I drove 5 miles with no issues.
    checked reverse lights. They worked (I don’t know if this faults when not working but mine were working so no confirmation there ).
    My car started in park just fine.
    I started it. Put it in N. Turned off. Then turned on and it fired up no problem. Sat for about 5 min running, light is gone.
    Let me rewind to it being set off …
    I was leaving on vacation. Normally when I do I park this truck behind my old 94 pickup so it doesn’t walk off while I’m out of town.
    The night before I didn’t do this. So we were leaving for our trip and I was in a hurry. Grab my keys repark and run back to my wife’s truck and we head out of town. In my hurry I believe I didn’t fully seat the car in park. Instead I put it somewhere in the middle of park and R. Then On my return I used the remote start and I heard an extra chirp. Boom light shows up.
    Hope it helps someone in the future.
    shifty` likes this.
