Neutral and reverse act like drive.
Discussion in '2nd Gen Tundras (2007-2013)' started by kluever47, May 24, 2018.
  1. May 24, 2018 at 5:36 PM
    kluever47
    kluever47 [OP] New Member
    Andrew
    2013 Tundra
    I have a 2013 Tundra and the neutral and reverse act like its in drive. At first the Tundra wouldn't shift over 3rd gear and the transmission warning light was on and the 4 LO was flashing. It will now shift above 3rd and the warning lights are gone. The neutral and reverse are still not working properly. I used a code reader so maybe it cleared the code and turned the warning lights off. I drove 15 miles on freeway and lights would not come back on. Dealership said there was a dent in the transmission pan and it may have blocked the intake of transmission fluid. I had the dealership bang the dent out and that did not fix the issue. I have since taken it to a transmission shop and they are still lost. They will have to tear down and rebuild. Any help or past experiences appreciated.
  2. Jun 5, 2021 at 9:02 PM
    Tcueva42
    Tcueva42 New Member
    Tristyn
    2008 green tundra trd 5.7
    I’m having the same problem with the reverse being neutral and neutral being drive after replacing solenoids did you find a solution?
  3. Jun 5, 2021 at 9:24 PM
    The OP never responded after that single post, pretty much 3 years ago now....
    Booney likes this.
  4. Jun 5, 2021 at 9:28 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Did you mess with the shifter cable? If you did put the shifter in neutral and the trans then tighten the bolt
  5. Jun 6, 2021 at 4:04 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    My guess is the OP is stuck in a 3-point turn.
  6. Jun 6, 2021 at 4:37 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Rip Van Winkle? Maybe he just woke up.
  7. Jun 6, 2021 at 5:03 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
