Neighbor dropped his car on his rotor
Discussion in 'Wheels & Tires' started by joonbug, Nov 18, 2017.
  1. Nov 18, 2017 at 1:30 PM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So I get a knock on my door and it’s my neighbor saying he needs help with his car. I go outside to see his car sitting on the front driver’s side rotor. :facepalm:Apparently he had a flat and the car tipped over while on the jack. I say no worries and roll my floor jack out there. I set up the jack but the frame and the rocker panels are both about 3 inches from the ground and can’t slide the jack under the car. Even his stock jack needed about 4 inches and I couldn’t find a safe jacking point at least 4” high. I’m a relatively good problem solver but I was stumped. Sat there scratching my head for 5 minutes and finally thought of using the jack from my Lotus. Thank goodness it’s a super low profile jack and it barely fit going in through the wheel well.
    Once I got the car up in the air, he gets the wheel on and starts tightening the lugs with the car up in the air. Now I’m starting to understand how this could’ve happened. Had to tell him to wait to get the car on the ground before fully tightening the lugs. And also had to tell him to tighten in a star pattern. Just stuff men should probably already know.
    Just curious, if I didn’t have the low profile jack, what else could I have done? Was there any other way to jack this car up? Only McGyver idea that popped in my head was to pull up another car next to it, put a big 2x4 under both cars and try jacking it up with my Hi-Lift jack. :notsure: Not sure how safe that would’ve been though. Lol.
    Krezz, TundraTss, T500 and 3 others like this.
  2. Nov 18, 2017 at 1:38 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I’ve had similar situations.
    Start at a spot along the frame or a crossmember where you’re able to fit your jack in and after lifting there, block it up and move the jack over. Maybe you have to do it several times
  3. Nov 18, 2017 at 1:43 PM
    Well you could have laughed, said call AAA, and slowly close door with a creepy smile on your face.
    I didn’t know you had a Lotus. Fun track day cars.
    Exhaust jacks work good and you should have one if you play in the desert.
    Other than that, low profile jack is what I would use. Hi-lift would be sketchy. Hopefully you showed him what jack stands, parking brake, and wheel chocks are for.
    Baja Mike, big_jarv, Pudge and 2 others like this.
  4. Nov 18, 2017 at 1:44 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Burke bar and some 2x4s.
    Get one and you will wonder how you ever lived without it.
    joonbug[OP] likes this.
  5. Nov 18, 2017 at 1:45 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Pull your fork lift that you have parked next to your Lotus out of the garage and use it to lift the entire car. ;)
  6. Nov 18, 2017 at 1:48 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Funny, first thing I asked was... “You have AAA?”
  7. Nov 18, 2017 at 1:48 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Looking up Burke bar now.
  8. Nov 18, 2017 at 1:50 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    So pry the car up? On the frame??
  9. Nov 18, 2017 at 2:07 PM
    Tacogrande
    Jeremy
    Im really not sure if it would work but it would be worth a try...leverage.
    Iv never tried a car like that...just an idea.
    The bar that i have is a Kraft HD Big John Pry Bar. I have moved sheds, 2400 lb safe, 1800 lb safe and large industrial machinery with just my wife and the bar. Its great for demolition...any thing big you need to deal with.
    joonbug[QUOTED][OP] likes this.
  10. Nov 18, 2017 at 2:13 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    I actually think it would’ve worked. Only needed to get the car up about an inch to get the jack under.
  11. Nov 18, 2017 at 3:14 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Couldn’t get it under the frame anywhere on the front half of the car. It was a pretty low Lexus.
  12. Nov 18, 2017 at 3:18 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Pictures of said Lotus needed please...
  13. Nov 18, 2017 at 3:36 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Why didn't you just deadlift it so your neighbor could slide the jack under the car?
    4x4_Angel, blizz86 and Tundra9831 like this.
  14. Nov 18, 2017 at 3:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If you have to start at the rear axle or the opposite side it is still usually a solution. In other words, it’s not needed to start at the front half.
  15. Nov 18, 2017 at 3:54 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    What kind of Lexus? I would jack it from the rear driver jack point. I can lift entire cars up front any side. If not slide a stand in then relocate your jack.
    :worthless:
    joonbug[OP] and gosolo like this.
  16. Nov 18, 2017 at 3:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Exactly what I was thinking.
    MotoTundra likes this.
  17. Nov 18, 2017 at 4:00 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s old, dusty and currently under a ton of cardboard boxes. Used to be my DD about 15 years ago before I got married. Actually haven’t even really driven it since having kids. Here’s an old pic.
    After putting a lot of work into it.
  18. Nov 18, 2017 at 4:03 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    What do I look like the Incredible Hulk? o_O
    4x4_Angel and TXMiamiFan[QUOTED] like this.
  19. Nov 18, 2017 at 4:04 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    When I was 17 (young and stupid) I did the something similar. At that time I knew about breaking the bolts while it was on the ground, the star pattern, etc., but really thought the scissor jack would support the car if I were to open/close the door. NOPE!
    Fortunately nothing important was under the car. The scissor jack that came with the car slid under the frame and I was able to get it back up. If I remember correctly the scissor jack went down to about 3" or so.
    My parents divorced when I was young and I would try to do everything I could with my dirt bikes/vehicles myself, but often lacked having someone to show me the correct way. Even at the MX track when I was young it was usually just my mom and I. My friends' dads would do all their bike maintenance whereas I had to learn it all myself. I was able to rebuild a top end in H.S. though.
    A lot comes down to if someone was taught properly, and I hate to say it but if they have common sense, haha.
    I learned a big lesson that day!
    mdavis and joonbug[OP] like this.
  20. Nov 18, 2017 at 4:06 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    That pos out there. What is that, a older GS?284387D1-EDA4-4A91-A405-A40063DB99A5.jpg
  21. Nov 18, 2017 at 4:09 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Problem was the rotor was on the ground and I just figured raising the back any would just put more weight on the rotor.
  22. Nov 18, 2017 at 4:49 PM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    :benchpress::curls::muscleflexing: Just pick it up by hand and slide the jack under!
    joonbug[OP] and TXMiamiFan like this.
  23. Nov 18, 2017 at 5:48 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That’s a pos ES. ES300 I think. Oh well lol. Good thing he had you to help.
  24. Nov 18, 2017 at 6:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Put wood blocking under the subframe ahead of the “front axle” fitted as tightly as possible, then jack up the rear or the car, and support with a stand. By then, you should have plenty of room for a floor jack under the back of the subframe.
  25. Nov 18, 2017 at 7:01 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    This happened to me once, kinda.
    My GSA got a flat and the shitty jack that came with the car wouldn’t fit under it at any decent spots to I had to literally jack it up a fraction of an inch at a time.
    Ruined my day, it did.
    God speed to anyone who finds themselves in this position.
    4x4_Angel and joonbug[OP] like this.
  26. Nov 18, 2017 at 7:04 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Daaamn.
    That’s sweet dude. I feel like that’s something you’d see Tom Sellick whipping around circa 1980s.
    Reminds me of the Lambo Countach.
  27. Nov 18, 2017 at 7:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    He bought it after he saw Julia Roberts all over it....
  28. Nov 18, 2017 at 7:50 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    I got to drive a Lotus Europa once when I was 17. It was in 1973 or 74. the last year they made them was 75. I'll never forget it. Great handling car.
    What model is that?
  29. Nov 18, 2017 at 8:20 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    90 Esprit SE turbo. Same car as Pretty Woman and Basic Instinct.
  30. Nov 26, 2017 at 9:08 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
