Neglected Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Tondruh76, Jun 8, 2020.
  1. Jun 8, 2020 at 4:13 PM
    Tondruh76
    Tondruh76 [OP] New Member
    Cesar
    2000 Tundra SR5 4x4
    None
    Took it to an independent Toyota repair shop for a thorough inspection. Below are the results.
    So I'm the 4th owner. 294140 miles.
    Many wear and tear items were neglected.
    Needs Rack and pinion Outer tie rods Flush steering system Alignment
    Timing belt Water pump Tensioner Idler Serpentine belt Coolant hoses
    Carrier bearing U-joints Carden joint
    Front & rear diff flush Transfer case flush
    Transmission mount Engine mounts Both CV axles
    I changed the engine oil and filter. Oil was black.
    Will be replacing the original factory suspension which is worn out with a nice lift kit.
    Truck should be good as new after all this.
  2. Jun 8, 2020 at 9:12 PM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    If you're paying someone to do all that, I hope you got a deal on it. If the compression is good I wouldn't flinch at sinking money into the rig myself.
    In addition, while you are in there, you might consider: steering rack bushings, sway bar end links and bushings, and factory suspension height (or close to it, not too tall) when you "lift" consider replacing the springs (rear leafs as well) at that mileage.
    Are the engine mounts bad? What year is the tundra? Did they mention anything about the radiator and/or transmission fluid? V6 or V8?
    Semper Fi
  3. Jun 8, 2020 at 9:55 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    My body is trashed from my Marine Corps days so yeah I have to pay someone to do it. As for a good deal on the work, considering the amount of work and how long it will take to do I think I'm getting a decent deal.
    Engine mounts are bad and it's an early 2000 model built in 1999 per the door sticker.
    It's a V8 and still runs strong and that's a good question about the transmission. It shifts fine but best to check/change the fluid.
    Radiator is fine, coolant will be replaced as the coolant hoses are being replaced along with the water pump.
    Steering rack bushings will be getting replaced.
    A lift is next on the list after all this other work is done first.
    Oorah.
  4. Jun 8, 2020 at 10:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Tondruh76
    Watching this thread to see your progress. I am glad you are fixing it. Once all this work is done you can stop being reactive, and start being proactive.
    My '02 V6 has 314K. Soon you will be in the 300K+ club.
    Thank you for your service.
  5. Jun 9, 2020 at 5:54 AM
    3.4Tundra
    3.4Tundra New Member
    Greg
    So. California
    2006 V8 Tundra 2wd
    Bilstein 5100
    If you haven't read about ball joints on these trucks, they are a definite maintenance item. Mainly the lowers. The consensus is that OEM is the way to go on these.
    And while you're in there, check out the control arm bushings. I've never done these on either of my two First Gen Tundras but I never had that kind of mileage either! Anyone else have input on these?
    Look forward to seeing your progress!
    Luckydog and Tundra2 like this.
  6. Jun 9, 2020 at 7:52 AM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    The lower ball joints looked fine on inspection. The UCA bushings however do have a bit of play. My plan is to replace them with some aftermarket UCAs like Camburg or Total Chaos when I do the lift. The suspension is worn out as well so it needs to be replaced.
  7. Jun 9, 2020 at 7:58 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Do you have any kind of exhaust tick? If so, while replacing the motor mounts would be a good time to switch to headers.
    Tundra2 likes this.
  8. Jun 9, 2020 at 9:11 AM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    No exhaust tick whatsoever. But, I'm planning on getting a new exhaust to open it up a bit and get more sound.
    Tundra2 likes this.
  9. Jun 9, 2020 at 9:39 AM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    I forgot to mention that all parts going on will be Toyota parts. Some of the parts being taken off were aftermarket parts.
  10. Jun 16, 2020 at 10:35 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    I got my truck back today with all the work completed. While the mechanic was doing the serpentine and timing belts, he found 2 of the 3 pulleys were showing noticable wear. Since he already had the belts off and everything apart, he recommended replacing the pulleys to save on future labor and to prevent a possible pulley failure.
    I took him up on his recommendation.
    The truck now drives much better, the steering wheels is now straight and there is no more noise when steering.
    The engine runs smoother thanks to the new engine mounts and there is no more vibration with the driveshaft u-joints being replaced along the with carrier bearing.
    I ordered an Icon stage 2 lift and camburg UCAs. They should arrive later this week. That will take care of the worn suspension which will complete the overhaul. It will be like a new truck after that.
  11. Jun 17, 2020 at 4:08 AM
    Professional Hand Model
    Hand Protectors
    Nice! Post up a pic of those old mounts if you can. We’d love to see their condition for future reference.
    Tundra2 likes this.
  12. Jun 17, 2020 at 4:39 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    If you can buy them cheap with a solid frame, engine, transmission and rear end, then they are usually worth fixing up. I have owned my 2002 since 2003, but my Gen 2 is similar to your 1st gen in that I am the 4th owner and it had 270,000 when I bought it cheap almost 3 years ago. Enjoy bringing your Tundra back up to speed, they are great trucks.
  13. Jun 17, 2020 at 1:53 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    I didn't take pictures of all the damaged parts. But here are some pics of most of the new parts.
  14. Jun 17, 2020 at 1:56 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    All new and shiny.
  15. Jun 17, 2020 at 2:00 PM
    Hand Protectors
    How did you know your motor mounts were bad? Stoked on your new stuff!
  16. Jun 17, 2020 at 2:04 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    Upon inspection, the rubber was severely cracked on the mounts. They were the originals seemed like. The lower control arm bushings were also dried and cracked. The eccentric sleeves were seized on one of the arms, and it had to be cut to remove the entire control arm.
  17. Jun 17, 2020 at 2:17 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Truck looks great! Since the cv axles are new you shouldn't have any issues with the boots leaking after the lift, but keep an eye on them, if you catch it early you can crimp the band a little tighter and it should be fine.
  18. Jun 17, 2020 at 2:24 PM
    Hand Protectors
    Yeah. The LCA seizing is typical on our trucks. I looked at my mounts a few weeks ago, but couldn’t see much other than what looked like some rubber block perimeter in good shape. Hard to see up in there so who knows?
  19. Jun 22, 2020 at 8:58 PM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    If you don’t mind me asking, what did that cost?
    sounds like you rebuilt everything but the drivetrain.
  20. Jun 22, 2020 at 9:18 PM
    Tondruh76
    Cesar
    2000 Tundra SR5 4x4
    None
    $8600 for all parts and labor.
