Negative terminal corrosion
Discussion in '2.5 Gen Tundras (2014-2021)' started by AAA96, Jan 22, 2023.
  1. Jan 22, 2023 at 9:01 AM
    AAA96
    AAA96 [OP] New Member
    2020 Tundra 4x4 SR5 CrewMax
    Anyone able to chime in about why I have green/white colored corrosion and buildup on the negative terminal of the battery? Also, best ways to clean and solve this problem. Thanks.
  2. Jan 22, 2023 at 9:08 AM
    Dirtrcr13
    Dirtrcr13 New Member
    Jerm
    03 Tundra// 16 4Runner
    The post is not completely sealed at the battery case (plastic) allowing some acid and/or fumes to escape, creating the fuzzy stuff. Easiest thing is to start the vehicle, remove the terminal so you can get under it, clean it all off with a rag or brush, rinse with fresh water, reconnect and then coat the terminal and end with grease or that battery terminal spray stuff.
    Saltyhero13 likes this.
  3. Jan 22, 2023 at 9:12 AM
    I use a battery terminal cleaner like the Noco below. A brass brush does great at descaling and getting back to clean terminals. Then those felt discs under the terminal and the CRC spray treatment below or equivalent to keep the corrosion away. Works pretty good. Also have kits available at local parts stores with all the stuff together.
    https://www.autozone.com/wash-clean...-ncp2-all-in-one-battery-saver-kit/257146_0_0
    D9818CCA-4A03-4FC8-9AF3-A3AB3435FA5D.jpg A43249FD-72A9-402B-8D39-57B4A06B5756.jpg
    FrenchToasty and texasrho83 like this.
  4. Jan 22, 2023 at 9:13 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    KNABORES likes this.
  5. Jan 22, 2023 at 9:13 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol. Great minds think alike.
    FrenchToasty likes this.
  6. Jan 22, 2023 at 9:15 AM
    In a pinch you can use baking soda and seltzer. Mix it together and pour it over the terminal.
    ATV25 likes this.
  7. Jan 22, 2023 at 9:15 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Or Coca Cola.
    TTund16, Wallygator and ATV25 like this.
  8. Jan 22, 2023 at 9:16 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Sounds like a party!
    TTund16 likes this.
  9. Jan 22, 2023 at 9:17 AM
    That could do damage to the paint.:notsure:
  10. Jan 22, 2023 at 9:24 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's for the battery not the paint, good Sir.
  11. Jan 22, 2023 at 10:03 AM
    I'm talking about the paint in the engine bay.
  12. Jan 22, 2023 at 10:14 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm aware. It was my poor attempt at levity.
    2mchfun and Jim LE 1301[QUOTED] like this.
  13. Jan 22, 2023 at 10:19 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Clean your battery terminals and then coat with Fluid Film. Does a great job.
    2mchfun likes this.
  14. Jan 22, 2023 at 10:20 AM
    :thumbsup:
  15. Jan 23, 2023 at 10:34 AM
    Rocko9999
    Rocko9999 New Member
    Anyway to seal the posts better? I have a good battery but no matter how much I clean it and spray protector on it, it sprouts a tremendous amount of corrosion within a month.
  16. Jan 23, 2023 at 10:43 AM
    2mchfun
    Maybe it's a small crack or broken seal where the post goes through the case or housing causing a leak??? Sometimes people tap on em a bit too hard.
    Dirtrcr13 and Rocko9999[QUOTED] like this.
  17. Jan 23, 2023 at 11:00 AM
    Those felt thingy’s
    nobodyintexas likes this.
  18. Jan 23, 2023 at 11:39 AM
    2mchfun
    Any chance the battery has some warranty time left?
  19. Jan 23, 2023 at 11:54 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    It is usually cuz by an actual leak and/or out gassing...the battery case does not have an ideal seal on the post itself.
    2mchfun likes this.
  20. Jan 23, 2023 at 12:00 PM
    Wallygator
    Take the terminals off. Use coca cola and a wire brush to clean off the terminals and posts. Rinse everything off with water. Dry everything and put the terminals back on the posts. Then spray with a protectant or use grease.
    I use Amsoil HD metal protector on them because it dries to the touch.
  21. Jan 23, 2023 at 12:04 PM
    Rocko9999
    Thanks.
    Strange it's been 3 batteries in a row. I have never cleaned battery terminals more in my life. Different brands too.
  22. Jan 23, 2023 at 12:07 PM
    2mchfun
    Aliens are messing with you! Even worse, they are winning!
    Rocko9999 and Wallygator like this.
  23. Jan 23, 2023 at 12:16 PM
    matictundra
    Franco
    AZ
    Overtime; expansion, contraction and vibration break the seal. Nothing last (in this case perfectly sealed) forever.
    2mchfun likes this.
  24. Jan 23, 2023 at 12:18 PM
    2mchfun
    So true, even in production and transportation prior to the retail outlet. So many possibilities!
  25. Jan 23, 2023 at 1:22 PM
    Dirtrcr13
    Jerm
    Use some regular ol wheel bearing grease. Take the terminal off, apply and work it in with your finger, then put the felt pad down, and coat it with grease. Its an old trick, but still works. Even on the "sealed/ maintenance free" batteries...
    Rocko9999[QUOTED] likes this.
  26. Jan 23, 2023 at 2:10 PM
    TTund16
    TTund16 New Member
    I also use battery terminal anti corrosion fiber washers.
    Wallygator likes this.
  27. Jan 23, 2023 at 2:26 PM
    Rocko9999
    Thanks. I will try this.
  28. Jan 23, 2023 at 7:58 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    I see a lot of not so good advice in here. Don’t use baking soda and water, if that gets in the vents it will neutralize the sulfuric acid inside the battery cells and kill it. Use dedicated CRC battery corrosion cleaner and terminal protector like @KNABORES suggested. Also, don’t leave the car running and disconnect the battery and then reconnect it. That can cause a sudden power surge and damage PCMs, BCMs, etc.
    To answer your question on why it’s on the negative terminal, that’s generally as a result of battery undercharging. Conversely, corrosion on the positive terminal is generally sue to battery overcharging.
