Needle for joint lube where no zerks
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Js2017TRDPRO, Mar 16, 2025.
  1. Mar 16, 2025 at 10:32 AM
    Js2017TRDPRO
    Js2017TRDPRO [OP] New Member
    2017 Tundra TRD Pro Double Cab
    Since there are no zerk fittings on the upper ball joint, tie rod, etc. .... has anyone used a zerk needle attachment to their grease gun to shoot lube into the rubber seals on the joints? I see videos of people doing it on other vehicles but wondering if anyone here has tried on their TRD Pro setups. Thanks
  2. Mar 17, 2025 at 10:52 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Unless you see evidence of the existing lube leaking out, I would leave them alone. Start messing with the boots and it may affect fit and allow dirt and contamination inside.
    vtl likes this.
  3. Mar 18, 2025 at 5:45 AM
    Js2017TRDPRO
    The boot on the ball on the upper control arm is flat and all grease/dirt on the outside. I may start trying on this one as it seems to have leaked anyway.
  4. Mar 18, 2025 at 6:12 AM
    I’ve used a needle on my grease gun before to put grease in a joint with a boot but no zerk. Works fine. The needle makes a small flat cut into the boot that pretty much self seals. No hole is left behind as it is like a hypodermic non-coring needle.
