Needing a new/used 3.91 Tundra diff and looking for other options (Sequoia?))
Discussion in '2nd Gen Tundras (2007-2013)' started by Netwrok, Apr 28, 2022.
  1. Apr 28, 2022 at 10:01 AM
    Netwrok
    Netwrok [OP] New Member
    TK
    2013 Tundra Grade DoubleCab 4.6L 2WD w/ Column Shift
    Hello guys, I have a 2013 Tundra grade with 3.91 rear diff that has a broken pinion/ring gear. IE: Grinding popping and metal slurry in the fluid.
    I have tried ordering a new one but was told by 3 local(TN) Toyota dealers and one online retailer that part number 41110-0C010 is likely backordered until Late June or July.
    I found someone parting a wrecked Sequoia near me but the parts numbers do not match.
    Anyone know if these parts are compatible?
    PS: I had a Used Tundra 3.91 on order and somehow FedEx broke it before it got to me it was returned to the eBay seller. It's my only vehicle so I am looking for the fastest cehapest way to go until I can get a new replacement in.
  2. Apr 28, 2022 at 10:26 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    hmmm maybe not the answer you were looking for, but what about looking at Yukon Gear & Axle and see if they sell the same gear ratio for your truck, or maybe regear to something a little different to get you going?
  3. Apr 28, 2022 at 11:08 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Sequoia is Independent Rear Suspension while Tundra is solid axle, so no go.
    Greg
    joseph_womack likes this.
  4. Apr 28, 2022 at 12:44 PM
    Netwrok
    TK
    Thanks for the suggestion, I just checked and they do not have the assembly available.
    I am also not equipped for rebuilding it myself or I would go that route.
    That's a shame, thank you for the update.
    joseph_womack[QUOTED] likes this.
  5. Apr 28, 2022 at 12:52 PM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    It's 2WD, can you afford to re-gear to anything available? 3.91, 4.30, 4.56, 4.88 are all options for that truck.
  6. Apr 28, 2022 at 1:03 PM
    Netwrok
    TK
    Best I can tell is that the 5.7L engines have a different axel housing for the 4.30 and larger diffs. They have a 10.5" ring gear while the 3.91 and 4.10 are 9.5" ring.
    With that I've only found Crew cab rear axles in my area and they have different mounts than a 6.5' bed/Double cab.
    If it wasn't the same cost as what I owe on the truck I'd gone ahead and ordered a whole rear axle+diff assembled from Toyota :(.
  7. Apr 28, 2022 at 1:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    If you find out the 4.30 will work, my truck is swapping its gears out as we speak so I'll have 2 sets of them on standby.
    WVI, Netwrok[OP] and joseph_womack like this.
  8. May 2, 2022 at 5:29 AM
    Tundradrenalin
    Virginia Beach, VA
  9. May 2, 2022 at 8:15 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You could put an aftermarket LSD in and get yourself back on the road.
