Needed HP
Discussion in 'Performance and Tuning' started by Black 1794, Nov 24, 2019.
  1. Nov 24, 2019 at 4:32 PM
    Black 1794
    Black 1794 [OP] New Member
    2019 Toyota Tundra
    2019 Black Tundra 1794
    OK, hello all. My first Tundra and coming from Fords my entire life I love the truck except MPG and HP. I figure the MPG is gone anyways because of 6" lift and 35's. But I need the HP to get up and go in Houston Traffic. Read some on here about exhaust increasing 45-50 HP???? Anyone can elaborate more on this. Thanks...
    Rica25 likes this.
  2. Nov 24, 2019 at 4:51 PM
    Steakbomb
    Steakbomb 2019 Super White DC SX
    Maine
    Rex Kramer likes this.
  3. Nov 24, 2019 at 4:57 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Teeth with dirty deeds has a set up with headers and exhaust that he was showing yields upwards of 75 horsepower and torque
    49hp 89tq
    tundra_20, dirtydeeds and Rica25 like this.
  4. Nov 24, 2019 at 4:58 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  5. Nov 24, 2019 at 4:58 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  6. Nov 24, 2019 at 4:59 PM
    Did you regear when you put the 35's on? If not, you aren't suffering a lack of power, you just aren't getting it to the ground effectively.
  7. Nov 24, 2019 at 5:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Re gearing is a great way to get your power band back closer to factory or even better
  8. Nov 24, 2019 at 5:08 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Put a super charger.
    Kerch71 likes this.
  9. Nov 24, 2019 at 5:34 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Exactly. Supercharger and exhaust change will give you significant hp and torque. Mine pulls 550 at the crank and 464 at the wheel with 475 ft/lbs torque. And I run 37s. I have 3" Magnaflow Flowmaster exhaust and long tube headers.
  10. Nov 24, 2019 at 5:35 PM
    You regeared though, didn't you? I'm just saying that if all he needs is get up and go in traffic, a regear should do the trick.
  11. Nov 24, 2019 at 5:39 PM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Press the tow/haul button then drive it around a bit. There is a pretty significant difference in mine when I do.
  12. Nov 24, 2019 at 5:46 PM
    Kerch71
    Mechanicsville VA
    Excellent point sir. Yes, I did regear. Hadn't thought of that, but a regear might be all that's needed. Or, he could do it all and have 1 badass ride.
    GODZILLA[QUOTED] likes this.
  13. Nov 24, 2019 at 5:47 PM
    For sure. You're truck is certainly badass! :bowdown:
    Kerch71[QUOTED] likes this.
  14. Nov 24, 2019 at 5:50 PM
    Kerch71
    Mechanicsville VA
    Appreciate the compliment, but this isn't about me. Well, maybe a little. Everyone should experience this! It's quite exhilarating!
    Midway and GODZILLA[QUOTED] like this.
  15. Nov 25, 2019 at 7:31 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Give a call. I can help. 760-877-4234
    15whtrd likes this.
  16. Nov 25, 2019 at 11:59 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    If your wanting to regear, hit up my buddy Erick at State48Overland. He can get you squared away with a great deal on gears!
    cctxquicksand likes this.
  17. Nov 25, 2019 at 12:03 PM
    15whtrd
    15whtrd Mr. Blonde
    Re-gear along with long tube headers and true dual exhaust. Don’t go true dual unless going long tubes. Dirtydeeds is your man.
