Need wisdom (experience) on replacing transmission in 2003 SR5 Access Cab
Discussion in '1st Gen Tundras (2000-2006)' started by mbcpurple, Sep 15, 2018.
  1. Sep 15, 2018 at 11:39 AM
    mbcpurple
    mbcpurple [OP] New Member
    2003 Tundra SR5 Access Cab V8
    Greetings,
    New here so please don't judge me ;) My dealer in Sacramento says I need a replacement tranny $5000, it'll take a week and they'll provide a loaner. Service guy's attitude on the phone was one of discouragement.He's just trying to "look out for me" in spending all that money and other stuff could go wrong down the road. I'm not looking for a "Genie" just want to fix my truck I've had since 7K miles, now approaching 250K. Has anyone had "experience" replacing the tranny of a Gen1 Tundra and what are your thoughts? Thank you :help:
  2. Sep 15, 2018 at 12:39 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    What is it doing?
  3. Sep 15, 2018 at 1:37 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Have you let a non-dealer transmission shop take a look at it? It may be able to be rebuilt or swapped for a rebuilt one at a lower price.
    If replacement is needed, there is a market for used ones as well.
  4. Sep 15, 2018 at 1:39 PM
    mbcpurple
    After backing up stopping and putting truck into drive, I've been hearing somewhat of a clanging for several weeks or so.
  5. Sep 15, 2018 at 1:42 PM
    mbcpurple
    I have not let any non dealer look at it yet but will, thanks for suggestion.
  6. Sep 15, 2018 at 3:25 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Are they sure it's the trans and not the carrier bearing or u joints? Maybe something in the diff? And does it do it if you don't reverse first? What kind of maintenance has the truck had?
  7. Sep 15, 2018 at 9:37 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    When was last rear diff service? Is there a “clunk”? You didn’t say if it was 2wd or 4wd. Have you lubricated the zerks recently? When was last transmission service?
  8. Sep 28, 2018 at 3:25 PM
    TGattis
    TGattis New Member
    Troy
    02 Limited x-cab
    I replaced the trans in my 02 SR5 Limited 2wd at 86K miles after the OD planetary imploded (common issue), fairly straight forward, put her up on jack stands on all 4 corners in my driveway and used a motorcycle lift to get it down and out, I bought a used trans from LKQ in town (Savannah, GA) for $475.00...It had 60K miles on it out of a 2004, I did have to change out the tail piece with the one from my trans, but it was simple. Took me roughly 10-12 hours with having to locate and pickup the replacement included....I'd do it again myself in a heartbeat. Currently that truck has 260K miles on it and will still give a Mustang a run for it's money...
    bmf4069 likes this.
  9. Sep 28, 2018 at 4:12 PM
    Blueknights75
    Ron
    Clayton, NC
    5K for a transmission?? Seems extremely high...
    Tundraboy likes this.
