Need Transmission Wiring Harness and "Valve Body"
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by Trueno, Jun 24, 2025 at 8:33 PM.
  1. Jun 24, 2025 at 8:33 PM
    Trueno
    Trueno [OP] New Member
    Will
    2006 Sr5 Dbl Cab
    Mechanic is telling my truck needs the "Transmission Wiring Harness" and the "Valve Body". transmission if I don't need to.
    For a little reference, I bought the truck from its original owner with 254K miles. It now has 259K. Aside from a little rust in the frame, the truck is in excellent overall condition.
    2006 Toyota Tundra DoubleCab V8 SR5 4WD 5TBDT44106S534603
  2. Jun 25, 2025 at 12:49 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    If it’s the A750, the wiring harness is known to corrode; why’d he say you need a new valve body?
  3. Jun 25, 2025 at 6:40 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Joseph, are you saying that the wiring itself may solve my problem?
  4. Jun 25, 2025 at 6:49 AM
    joseph_womack
    Joe
    Louisiana
    Not necessarily, what problem are you having?
    maybe if all your solenoids are going crazy it might just be a wiring issue; hard to say without seeing in person, or could be a single corroded wire
  5. Jun 25, 2025 at 11:20 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    I have codes P0710, P0712 and P0986. Truck even went on Limp mode.
    My mechanic also saw the damaged wires.
  6. Jun 25, 2025 at 8:16 PM
    joseph_womack
    Joe
    Louisiana
    whats the year make a model?
    2006 Tundra, V6 or V8, 4wd or 2wd?
  7. Jun 25, 2025 at 8:57 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    joseph_womack likes this.
  8. Jun 25, 2025 at 10:28 PM
    joseph_womack
    Joe
    Louisiana
    DTC P0710 Transmission Fluid Temperature Sensor "A" Circuit - either the wiring/connector/or sensor is bad
    DTC P0712 Transmission Fluid Temperature Sensor "A" Circuit Low Input - either the wiring/connector/or sensor is bad
    DTC P0986 Shift Solenoid "E" Control Circuit High (Shift Solenoid Valve SR) - short in the wiring/shift solenoid is bad/ or ecm is bad
    all three are strongly pointing to the wiring being the problem, and since we know the wiring corrodes on this tranny, thats a strong possibility. Why'd he want to replace the valve body too? (also you can ohm out the E shift solenoid to see if that is the problem if replacing the wiring harness doesn't fix it.)
