Need Toyota tech help....
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bwalker3, Aug 25, 2024.
  1. Aug 25, 2024 at 12:25 PM
    Bwalker3
    Bwalker3 [OP] New Member
    None
    I have a crank, no start problem on my 14 SR5 CCSB 4x4. 108K miles and not a single issue until this morning. I have fuel in it and have disconnected the fuel line to the driver side fuel rail at the back of the engine. When I crank there is no fuel coming out of the fuel line. I verified 12 volts at the blue wire on the fuel control module. If I disconnect the red and blue wire connector from the control module. Run a 12 volt power wire and ground from the battery, can I simply connect them to this connector and expect my fuel pump to run?
  2. Aug 25, 2024 at 12:30 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Could be a bad fuel relay...
  3. Aug 25, 2024 at 12:38 PM
    Bwalker3
    None
    Thanks for the suggestion but I changed it with a known good one, no difference.
  4. Aug 25, 2024 at 12:47 PM
    sm_tundra
    sm_tundra New Member
    2018 Tundra Limited
    Bad pump.
  5. Aug 25, 2024 at 12:55 PM
    808Tunderer
    808Tunderer New Member
    2021 DubCab SR5 4x4 TRD Offroad
    Stock
    I assume you have checked obII for codes?
  6. Aug 25, 2024 at 12:56 PM
    Bwalker3
    None
    Do you know of an iron clad way to test it?
  7. Aug 25, 2024 at 12:58 PM
    Bwalker3
    None
    Yes and there was none
  8. Aug 25, 2024 at 3:20 PM
    Bwalker3
    None
    Ok, update in hopes of helping someone down the road. If you disconnect the plug that has the red and the blue wires from the fuel control module and you jumper 12v to the blue and ground to the red it should run the pump. You have another connector at the top of the tank and one inside the tank. If you don't hear the pump running inside a very quiet environment You will need to drop the tank and check the other 2 connectors. You can also check the pump itself once it is removed from the tank. Mine tested good once I got it out of the tank but I am going to replace it to ensure it doesn't have this same issue in the near future at a less convenient time or place. I hope this helps someone else.
    ForceV4, 1UP, texasrho83 and 2 others like this.
  9. Aug 25, 2024 at 4:25 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    :confused: If pump tested good what was/is the problem?
    Black Wolf likes this.
  10. Aug 25, 2024 at 4:44 PM
    This^^^^^^
  11. Aug 25, 2024 at 5:28 PM
    Bwalker3
    None
    The problem is it only tested good after I got it out. It wouldn’t work while it was in its natural state telling me it’s either intermittent or that it had something lodged in it. Either way, I have been down that road before so I will spend a little money and buy a new pump and dielectric grease all the connections.
  12. Aug 27, 2024 at 4:19 PM
    Bwalker3
    None
    Update**** ordered a new oem pump from Toyota. Put it in this afternoon and she fired right up. Thanks for everyone’s suggestions and ideas.
    1UP, morgaj1 and Leo's first like this.
  13. Aug 27, 2024 at 6:49 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Happy to hear your good news. BTW just in case you didn't know this thread existed
    https://www.tundras.com/threads/ask-the-toyota-mechanic.2404/
