Need to upgrade Suspension of 2018 Tundra.
Discussion in 'New Member Introductions' started by TTL, Sep 9, 2022.
  1. Sep 9, 2022 at 10:30 AM
    TTL
    TTL [OP] New Member
    Let me start by saying I have no idea what I am doing. My end goal is put the heavy camper on Tundra. Someone suggested to me upgrade the suspension and put the 35inch tire.
    I am thinking to install the Old Man Emu kit (OMETUN57HKS) I believe this gives me around 2.4 inch lift.
    1- Does anyone has Old Man Emu with 35inch tire. ?
    2- Please feel free point me to economical suspension brand which are reliable and can hold the heavy camper.
  2. Sep 9, 2022 at 10:33 AM
    timsp8
    NY
    How heavy of a camper? If thats the reason for the change in suspension, getting a lift and bigger tires is the opposite of what to do. You’ll kill your mpg even more and cut in to your payload.
    I have airbags for short heavy loads, but alot of people recommend roadmaster active suspension.
    2018TundraLimited likes this.
  3. Sep 9, 2022 at 10:39 AM
    TTL
    TTL [OP] New Member
    Thanks for quick response. Camper + passenger weight around 2300 pound.
  4. Sep 9, 2022 at 10:42 AM
    timsp8
    NY
    Check your payload sticker. Thats probably about 1000 lbs over. You’ll have more issues than sag - brakes, frame, wheel bearings. The tundra isn’t the truck for a camper. Did you factor luggage, gear, water, food?
  5. Sep 9, 2022 at 10:42 AM
    Azblue
    The Dirty T ( ^_^)_且
    Get a bigger truck. That's way too much for any 1/2 ton truck, regardless what you do to the suspension.
  6. Sep 9, 2022 at 10:47 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    2300lbs! Yea.. economical and that weight don't go together lol
  7. Sep 9, 2022 at 10:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Need a 2500 HD truck for a slide in like that. Tundras generally have payloads in the 1240-1500 range and the higher range means a 2wd with minimal options/add ons.
    on Suspension, yes OME is good, long lasting. There is a dedicated thread on the suspension with lots of pics and good info in the suspension forum here.
  8. Sep 9, 2022 at 10:59 AM
    TTL
    TTL [OP] New Member
    Appreciate inputs. What is the max weight I should put on the Tundra. I did not bought camper yet so I can always buy light weight camper.
  9. Sep 9, 2022 at 11:02 AM
    TTL
    TTL [OP] New Member
    Great, I should be targeting 1240-1500. I live in NJ, does anyone know 4WD/camper people/shop in NJ.
  10. Sep 9, 2022 at 11:44 AM
    timsp8
    NY
    Look at the payload sticker on your door jamb. Or to get more accurate, go weigh your truck and subtract that from the gvwr which is usually 7200 for the tundra (some 2wds are 7100). You also have to factor in the weight of everything you will carry in addition to any camper.
  11. Sep 9, 2022 at 11:55 AM
    TTL
    TTL [OP] New Member
    Thanks for pointing me to right direction. I thought it will be easy , I will just buy camper and hit the road, what an idiot I am, I will start from weight calculation.
  12. Sep 9, 2022 at 12:45 PM
    timsp8
    NY
    Yeah my retirement plans are to travel for awhile with a camper. But I plan to get a 1 ton truck before then and not worry about payload. My only buyers remorse with the tundra is payload.
  13. Sep 9, 2022 at 3:38 PM
    TTL
    TTL [OP] New Member
    which brand airbag you are using ?
  14. Sep 9, 2022 at 3:47 PM
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    These guys are a Four Wheel Popup Camper dealer in West Chester, PA
    https://www.mainlineoverland.com/
  15. Sep 10, 2022 at 7:06 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! And good luck with setting your truck up.
  16. Sep 10, 2022 at 9:12 AM
    timsp8
    NY
    I have airlift airbags with daystar cradles. They are easy to install. I also got their compressor so I can adjust psi anywhere, but I see a lot of people run the air lines to the rear license plate to fill easily.
  17. Sep 10, 2022 at 9:22 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    People, pets, water, food, tools, Appliance, beds, clothes, and mods
  18. Sep 10, 2022 at 9:02 PM
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    When I got my camper (FWC Granby) I weighed the truck empty and then weighed it with the camper loaded. Sent the numbers to Alcan Springs told them I was doing a 2.5" system and they did the magic, no complaints.
  19. Sep 11, 2022 at 6:32 AM
    TTL
    TTL [OP] New Member
    any idea how much your Tundra is over the recommended payload. what is 2.5" system ? appreciate your help.
  20. Sep 11, 2022 at 8:34 AM
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    I went with 2.5 from ADS. I'll have to look up my weights but the camper is in the 1500# range.
    https://adsshocks.com/
