Need to trim front bumper, ideas?
Discussion in 'Suspension' started by mahmer09, Dec 20, 2019.
  1. Dec 20, 2019 at 10:08 PM
    mahmer09
    mahmer09 [OP] SR5 4x4
    Just got 6112s put on at 1.9. 285/75/17 on Method wheels. The tires are rubbing on the front bumper. Feel like I need to trim a four inch long, 1/4 deep out of the bumper. What tool do I need? It’s the only part that rubs and seems so doable. I just don’t know what to do. Thanks in advance for the suggestions!
  2. Dec 20, 2019 at 10:13 PM
    619tundra16
    619tundra16 New Member
    You should look into some of coachbuilders front bumper spacers before you go hacking away at your bumper.
  3. Dec 20, 2019 at 10:27 PM
    mahmer09
    Hilarious. I was in research mode, watched a video ready to order a grinder. A comment said to just get a shim. Ordered it and then you commented. Since you did, just out of curiosity, are they easy to install?
  4. Dec 20, 2019 at 10:31 PM
    619tundra16
    I couldn't tell you about the install process because I never got around to installing mine but I'm sure theres a write up out there somewhere on it.
    I'm pretty sure I saw it before I ordered my set.
  5. Dec 21, 2019 at 7:58 AM
    mahmer09
    So did you cut the bumper? I did order the shims but am impatient. What’s the downside of cutting the bumper?
  6. Dec 21, 2019 at 7:37 PM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    Bumper shims. Still rub, a dremel to cut front liner, and or, heat gun to move front liner forward. Don't be afraid to :sawzall:
