Need to Replace My Water Pump
Discussion in 'General Tundra Discussion' started by EPecora, Sep 23, 2021.
  1. Sep 23, 2021 at 12:37 PM
    EPecora
    EPecora [OP] New Member
    Evan
    Pennsylvania
    2013 MGM CrewMax Rock Warrior
    2013 Rock Warrior Tundra-Had my truck in for inspection the other day. Dealer recommended that I replace the water pump, said it was low on coolant and noticed some leaking from the water pump. From what I can tell this is a common thing. Dealer quoted this at $828+tax. Just looking to see what everyone thinks about this quote? Seems middle of the road to me and I trust my dealer so I’m leaning towards having them do it. Appreciate your thoughts!
  2. Sep 23, 2021 at 1:31 PM
    ZiaTundra
    ZiaTundra New Member
    I got a quote of $600 from a service shop and $800 from Toyota. YouTube has some good DIY tutorials and will get you through it for around $289.00 in parts. If you do it, don’t remove the radiator like one of the tutorials instructs. No reason to. Removing the fan and shroud will give you enough room. You can get to the tensioner pulley from under the truck to take off the belt.
    water pump
    Coolant
    Belt
    Bleeding funnel
  3. Sep 23, 2021 at 1:33 PM
    timsp8
    NY
    The water pump on my 2010 went out at around 60k. It was about $800 to replace it at Toyota.
