Need to order TRD pro grill and TSS relocation bracket
Discussion in 'General Tundra Discussion' started by scottywill101, Jan 24, 2021.
  1. Jan 24, 2021 at 8:12 AM
    scottywill101
    scottywill101 [OP] New Member
    Scott
    Sellersburg, Indiana
    2018 Platinum CM
    3/1 Lift
    Could someone please tell me what I need to order to put a TRD pro grill and TSS relocation bracket on? I'm hoping this will fix the PCS error that has popped up.
    TIA,
    Scott
  2. Jan 24, 2021 at 8:29 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
  3. Jan 24, 2021 at 8:35 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I had issues with the ajt bracket; as have others. Some have had no issues with it. I kept getting the error - my thought is the face plate of their bracket is too thick.
    I replaced with the jomax bracket and haven’t had an issue since. YMMV
  4. Jan 24, 2021 at 8:36 AM
    Blueknights75
    Ron
    Clayton, NC
    You don’t need the bracket if you are looking at purchasing the newer PRO grill. If you are looking at a 17’ PRO grill then check out the Ares or Jomax relocation bracket.
  5. Jan 24, 2021 at 8:38 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
    Would I not need the relocation bracket to drop the sensor down due to my leveling lift? Does the new PRO grill relocate the sensor?
  6. Jan 24, 2021 at 8:41 AM
    Blueknights75
    Ron
    Clayton, NC
    The 19’ and up PRO grill has the sensor bracket a little lower. I have a level kit with the sensor still in the original location which is behind the Toyota emblem. You don’t need the relocation bracket unless you are going to install the 17’ PRO grill.
    Jim LE 1301 likes this.
  7. Jan 24, 2021 at 8:45 AM
    ^^This^^
    Blueknights75[QUOTED] likes this.
  8. Jan 24, 2021 at 8:59 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
    I just ordered the newer PRO grille. I'm assuming I will have to have the dealership recalibrate the sensor.
    Thanks guys,
    Scott
  9. Jan 24, 2021 at 9:04 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    You may not need to...I switched to a pro grill and never had any issues.
  10. Jan 24, 2021 at 9:05 AM
    Blueknights75
    Ron
    Clayton, NC
    You may or may not have to recalibrate. Odds typically are that everything should be fine. Keep us informed and send us some pictures...
  11. Jan 24, 2021 at 9:06 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
    But was the sensor working prior to you putting in the new grille?
  12. Jan 24, 2021 at 9:16 AM
    Did you also order the sensor cover?
    No need on recalibration.
  13. Jan 24, 2021 at 9:19 AM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Yes never had an issue before or after...bought a 3rd gen ARES cover and no issue there either but he isnt making them any longer. Probably better for all concerned on that deal....
  14. Jan 24, 2021 at 9:58 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
    Yes, the cover comes with the grille.
  15. Jan 24, 2021 at 10:01 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
    My PCS and DRSS are currently not working. That is why after I install the new PRO grille, I believe I will have to have it recalibrated. I hope I am wrong.
  16. Jan 24, 2021 at 10:10 AM
    :thumbsup:
    I assumed you purchased the one from Toyota, not aftermarket.
  17. Jan 24, 2021 at 10:19 AM
    scottywill101
    Scott
    2018 Platinum CM
    3/1 Lift
  18. Jan 24, 2021 at 12:40 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I’m not aware of any aftermarket pro grills just the garnish covers. I got mine at cool springs Toyota. The oem garnish cover is still highway robbery
  19. Jan 24, 2021 at 2:08 PM
