Need to eliminate door stopper clicking, groaning
Discussion in '2nd Gen Tundras (2007-2013)' started by Albertaktm, Aug 9, 2024.
  1. Aug 9, 2024 at 5:49 PM
    Albertaktm
    Albertaktm [OP] New Member
    Ferrari
    Cheese burger
    On my front passanger door ( of all places), there is a loud click when I open the door when ever the jam mounted stop arm passes over one of the detents. 3 in all. I sprayed in a bit of lithium grease but it just sounds worse. Any solution or am I replacing the whole stopper assembly.
    Thanks
  2. Aug 9, 2024 at 5:58 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have seen the 10mm nuts come loose and the door makes a sound similar to what you're describing. If memory serves, the nuts are on the body side of the door restraint. Check those first.
  3. Aug 9, 2024 at 7:41 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Don't forget to clean and lube the hinges themselves. I have to clean and lube mine every couple of weeks due to dust. Even my door handles stick because of it.
  4. Aug 9, 2024 at 7:45 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    If the 10mm bolts aren’t loose, your door check is likely cracked.
    grave and Wynnded like this.
  5. Aug 11, 2024 at 6:55 PM
    Albertaktm
    Ferrari
    Cheese burger
    Thats what I think. I ordered one for the whole 30 bucks.
    Wynnded likes this.
  6. Aug 13, 2024 at 4:34 AM
    The Great Garbanzo
    The Great Garbanzo New Member
    2012 Tundra DC
    Boy looking at the install video I sure miss my T-100 w/manual windows, locks, no mirror controls.
    My new to me 2012 has the same issue...keep that on the to do "later" list
  7. Aug 13, 2024 at 12:01 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    this happened to my 06 4runner, 07 tundra, and 22 corolla cross. it's most likely the door check bolts coming loose. tighten those 10mms (if you can find the socket) and you're golden
    Wynnded likes this.
