Need Suggestions - off-road tires with stock and no lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by mynor213la, Aug 14, 2019.
  1. off road tires
    9 vote(s)
    100.0%
  2. spacers
    0 vote(s)
    0.0%
  3. wheels
    1 vote(s)
    11.1%
Multiple votes are allowed.
  1. Aug 14, 2019 at 4:09 PM
    mynor213la
    mynor213la [OP] New Member
    mynor
    17 tundra LMT 4x4
    none
    Hello Guys,
    im leasing a 2017 tundra CM, Limited, 4x4. i recently started off-roading with my son and we had a great time. However, im looking to buy some new tires and not sure where to start.
    so far, some say that 295/70/r18 will fit on stock wheels, others say 295/65/18.
    i want to have the someone off-road tire look 1.25" wheel spacers for a nicer look.
    i cant lift the truck or do any mods since i'm leasing it.
    what do you guys suggest?
  2. Aug 14, 2019 at 4:16 PM
    I dont think a 295 will fit without a level or lift. Im running a 285/70 on a 3 inch lift.
    Ely010606 and OR18TRD like this.
  3. Aug 14, 2019 at 4:18 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Agree
  4. Aug 14, 2019 at 4:21 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That's because you're running an aftermarket wheel with a lower offset. You can fit a 295 on stock wheels.
    Kerch71 and Black Wolf like this.
  5. Aug 14, 2019 at 4:23 PM
    Possibly. I am running a 0 offset on mine.
    joonbug[QUOTED] likes this.
  6. Aug 14, 2019 at 4:29 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    I run Goodyear Wrangler Duratrac All Terrains (snowflake logo) here in Colorado, stock size, no lift. They look badass, perform even better and it’s the only tire I’ve ran the last decade. There’s really no reason to push the limits on the size, go with a 285 and call it a day, you’re never gonna notice that vs. the 295 or whatever. I’ve played the stuff-the-tires, trim-as-necessary game before and no more.
    Ely010606, gosolo and OR18TRD like this.
  7. Aug 14, 2019 at 4:37 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    295 should fit stock, but if you're going to use spacers, they may rub because it changes your offset. Sounds counterintuitive but if you have a wider stance, the outer edge of the tire may catch the arch, in which case a 295 may not work. There are so many ways to do tires and rims, I'd ask a tire installation professional. BFG KO2 or Nitto Grapplers would be my offroad tire choice.:thumbsup:
  8. Aug 14, 2019 at 4:40 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    295's on a stock wheel with no wheel spacer will be close the the UCA. Without adding any sort of lift in the front your best choice for no to minimal rubbing is 275x70x18 or 285x65x18.
    Does you lease say that you can't modify the truck? You could lift the front with new coilovers and save the stock ones to put back on when the lease is up.
    joonbug and OR18TRD like this.
  9. Aug 14, 2019 at 6:00 PM
    CantleyTRDOFF
    CantleyTRDOFF New Member
    2016 Tundra SR5 TRD Off Road
    @OR18TRD No rubbing? I’ve seen in other threads that, that size does. I just bought a 16 TRD Off-road with the stock LTX’s but want something a little more aggressive looking and a tad bigger.
    OR18TRD[QUOTED] likes this.
