need some wheel suggestion help. 6" lift. 37's. 20". 0 degreeish offset
Discussion in 'Wheels & Tires' started by andy9743, Jul 4, 2018.
  1. Jul 4, 2018 at 5:47 AM
    andy9743
    andy9743 [OP] New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    hey guys. just got some crummy news. was running these rims on my tundra:
    http://4wheelonline.com/Pro_Comp_Wheels_7031_Flat_Black.142074.0
    the finish was getting crappy so i got them powder coated gloss black. got the center caps painted to match. tapped blind holes and powder coated some button head bolts red to set them off. one tire kept losing air, come to find out i have a crack in one of the spoke connection points. super bummer.
    my set up is pro comp stage 2 6" lift. 20" 37's. wheels were 9" wide and 0 degree offset. that offset worked well for my set up, i liked the look and they didn't rub so 0 or a bit wider would work great. i do not want a huge poke out past the flares or rubbing issues. i run bushwacker flares on the truck. i would like to get a gloss black wheel possibly a little wider (10" maybe?) with some red on it possibly. i liked the style of what i had with the spokes and a bit of lip. any suggestions on brands or wheels?
    thanks guys
  2. Jul 7, 2018 at 11:34 PM
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Do u happen to have a pic of this set up? I'm looking at same lift and really want 37's but curious how many other issues did u come across ie. gears etc.?
  3. Jul 9, 2018 at 6:13 PM
    andy9743
    andrew
    nw ohio
    Thanks
    I do. Give me a second to dig one up. O did gears. And a supercharger. It was on 35s before. Imo it needed gears with both the 35s and 37s. The supercharger helped a bit also..
    Corr2626[QUOTED] likes this.
  4. Jul 9, 2018 at 6:20 PM
  5. Jul 9, 2018 at 6:21 PM
    andy9743
    andrew
    nw ohio
    Also did spc ucas.
    GNTundra likes this.
  6. Jul 9, 2018 at 6:24 PM
